![]() | Home > Off Topic - Other Cars > MOT Query |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1465 ![]() ![]() |
My work hack (C5) is in for it's MOT later this week but is missing one of it's front spotlights. It disappeared when I hit a piece of debris on the motorway |
Hmmm, these are standard fitment spotlights so may not get away with it.... |
Standard fitment or not, unless they are required to be fitted under construction and use regs then you're OK to remove them.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
C5 Citroen ? |
Thanks mzplcg. Makes it a bit easier if I don't have to faff about before the MOT.
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
I think the single spot is ok as long as it is in the middle - in fact you can have as many as you want as long as they are paired at equal distance from the outer edge and any odd one in the middle. I dont think their laws are the same as ours, but I once saw a very old (1920's?) yank car with two headlights and a what looked like 20" plus centre spot! QUID FACIUM TIBI
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Disconnect the one which is remaining, that way you have none, or simply take out the fuse. Shouldn't be a problem as they are not required or tested as part of the MOT as has been said. There is nothing that can't be fixed with a hammer😜😜
Thanks all
