![]() | Home > In Car Electronics (L322) > Can an intravee give you faults? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
And more? Also got headlight undervoltage faults.. only started when I fitted intravee and enabled headlights to come on when I pressed key fob to open? I'm going to try unplugging unit then see if they come back..
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Anything that connects to the ibus has the power to throw up faults... I'd unplug the unit and see if the faults go |
Unplugged it last night.. zero faults today! At least I know what's causing them.. I think it's something todo with the headlight activation on unlock...car was fine before I enabled that feature.. cheers buddy |
So reset the options to factory, plug in you intravee and see what happens... you can live without the headlights on opening... FYI I found that even if the car was unlocked, pressing the open button on the key triggered the puddle lamps and interior lighting too, enough to ensure that I didn't fall in a pothole!! Yesterday I couldn't spell Engineer... Today I are one!
Reset the lot. Plugged back in zero faults. Decided to try and activate lights again and faults are back.. just shows how easy the system throws a fault.. now deactivated and all good. |
Is there a need for headlights on opening? If so you could trigger a relay to power some spots / led's with the interior lights and have them cancel with the ignition |
