Home > Maintenance & Mods (L322) > Where are my spark plugs? 2006 4.4NA AJ41 Jag Engine
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
have searched on here but can't find an existing thread or anything in the WIKI. I have removed the top engine cover, but all I see underneath that is a black plastic moulding that looks like air intakes to the cylinders - are the spark plugs located under this? Has anyone else replaced the plugs on one of these engines? Presumably if the plastic air inlet moulding has to come off to access the plugs i will need to be replacing gaskets / seals?
Have also looked in the workshop manual but can't find the relevent info (only seems to mention the 4.2SC engine, which is AJV8 rather than the AJ41 which is what i have). 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #427607 13th Feb 2017 5:07pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I'd assume it's like the supercharged engine, so a black plastic cover over the top of each bank (not in the valley between banks), under which you will see the top of the coil packs, pull those out and you will find the spark plugs.
Post #427625 13th Feb 2017 7:34pm
