Home > In Car Electronics (L322) > iPod connection
AshC
United Kingdom 2010 Range Rover Vogue TDV8 Alaska White
iPod connection
Hi guys,
Quick question. I just bought myself an iPod lead for the car plus an adaptor as I have a newer iPhone when I connect it all up it says connecting to iPod and then says device error!!
Is this because I'm using an iPhone rather than an iPod or is this a different issue?
Many thanks
Ash
Post #426895 8th Feb 2017 3:48pm
I think your problem is the 'adapter' as well as the iPhone - you'd be OK with an older iPhone & no adapter.....
The old connector had a set of analogue outputs - which is what the car needs.
The newer connector is all digital.
The adapter doesn't do digital to analogue conversion, just maps the digital pins & the power.
Post #426897 8th Feb 2017 3:55pm
AshC
Ahh ok. That makes sense. I think I have an old iPod somewhere. I'll dig that out and see if that works as I won't need to use the adaptor then. Thanks for the advice 👍🏻
Post #426898 8th Feb 2017 4:18pm
is it a proper apple adapter?
the cheaper ones dont have the DAC in them and as Alistair says they need this to send the analogue signal to the car.
It should work with a genuine apple adapter though i can go and check if you want. alternatively get a Bovee/tune2air which are sporadically on amazon and go bluetooth.
https://www.amazon.co.uk/Bovee-Wireless-Bl...ords=bovee There is nothing that can't be fixed with a hammer😜😜
Post #426950 8th Feb 2017 7:58pm
AshC
I've just tried it with an older iPod and it works perfect. It must be to do with the adaptor I bought to convert it so it fits a new iPhone. No real issue, makes use of my old iPod I suppose. Now just a shame I can't get the Bluetooth to work to allow calls!
Post #426971 8th Feb 2017 9:31pm
iPhone 7 works fine with mine.
Should work perfectly Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #426980 8th Feb 2017 10:34pm
