Home > Technical (L322) > Heating Transmission
Goodbloke1
New Zealand 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Hi, I have a 2003 RR HSE, 4.4L & 5 Spd ZF Auto. Several times when towing the boat , the trans seems to get hot & "derates". It will change down to 3rd , & not change up. Changing to manual/sport mode doesn't help. Do l need a Trans cooler or should I get it flushed ? It has done about 103,000kms
Any help/advice appreciated
Thanks
Post #426741 7th Feb 2017 6:23pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
The bottom of the radiator which I believe operates the transmission cooler is known to get blocked up with sludge and debris. Either flush your radiator or get a new one. The oil cooler could also be the culprit ?
Post #426750 7th Feb 2017 6:58pm
Rangeyman
Check any service history for new parts but unless they have been changed recently you need a new radiator and transmission cooler as they get blocked,you also need transmission oil as it deteriorates.there is plenty of info on this site about it .
Post #426976 8th Feb 2017 10:04pm
b348xyx
As both people said before, new radiator and gearbox cooler.
If you keep running the gearbox hot it will be damaged and you will need your gearbox reconditioned.
Make sure you get the gearbox oil changed at the same time 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #427013 9th Feb 2017 9:39am
Within the plastic manifold that the gearbox oil cooler attaches (which is on the left hand side of the main radiator when viewed looking into the engine bay) is a separate thermostat for the oil cooler, this can get blocked of break as well so it's best to change the whole lot, also the oil cooler pipes back to the transmission can delaminate and collapse preventing the oil from getting cooled.. If you can afford it it's best to change the lot, if not, take it all out and give it a good looking at and cleaning. It is virtually impossible to clean out the main engine radiator or oil cooler well enough to make any difference...
To sort the issue completely change
Main engine radiator (check and replace all hoses if the are at all hard or the plastic has gone from black to brown)
Oil cooler radiator
Manifold and thermostat
Oil cooler pipes.
Coolant
Transmission oil (the correct fluid, not generic stuff)
Then fit the cooler thermostat modification.
http://www.fullfatrr.com/forum/topic39362.html
Job done... Thumbs Up Pete
Post #427070 9th Feb 2017 5:22pm
holidaychicken
Re: Heating Transmission
Thanks
The cooling strategy is the reason it won't let you change up as it is trying to pump the oil around the cooler faster.
I changed everything above when I rebuilt my transmission apart from my radiator as when I flushed it through it was nice and clear.
I kept all my old parts except the pipes as they had to be cut off if you want a photo of any of it.
What sort of temperature was it when it started hanging onto gears and what budget are you working to?
Post #427118 9th Feb 2017 11:59pm
