Home > Technical (L322) > Battery light, then more, then shut down |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3163 |
Alternator dead or belt come off the pulley? |
29th Jan 2017 12:31pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Sounds very much like your alternator is failing to supply proper charge. However they would normally either fail completely, or be worse at tickover than high revs. Your combination of noise and failure to charge at high revs is more unusual. Perhaps something else is jamming at high revs, making the belt slip and failing to turn the alternator sufficiently.
29th Jan 2017 12:34pm |
joenrr Member Since: 29 Jan 2017 Location: mallorca Posts: 2 |
Thanks for the replies. Think that work is beyond my capabilities, but at least it gives me a start point to tell the garage.
30th Jan 2017 8:16am |
