Home > In Car Electronics (L322) > CREE LED cornering bulbs
I'm replacing all the driving bulbs I can with CREE's and have found that the fogs are going to take some cutting to fit and the high beams wont click in but I have made clips for that but I'm coming up blank on my cornering bulbs , no matter which way I plug them in they wont work and I get a general communication fault on them when I read the faults , any thoughts gentlemen ? 2008 MY Supercharged
Post #425378 29th Jan 2017 12:02pm
miggit
Not wanting to state the obvious... but have you checked the bulb off the car, just to rule out a dud? And I wonder if they are wired up the same way that the rear fogs are... cos they follow no logic and require a box of tricks to make them work on the rear when an LED conversion is done Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #425416 29th Jan 2017 4:00pm
They do work because I have tried them in the fog lights , that's how I know they don't fit Censored Laughing
The rear light conversion does not work due to different wiring but my problem must be more straight forward , the bulbs clip into the holder and simply don't work when I go round corners . Now could I have Censored my Light Control Module somehow or even something on the light itself? 2008 MY Supercharged
Post #425524 30th Jan 2017 12:22am
miggit
So if the "going around the bend" lights work with normal incandescent bulbs, I would suggest that you add some ballast resistors to increase the load on the circuit... there might not be enough load to activate the lights.. bit like LED's on a trailer, some work perfectly.. others cause all sorts of havoc, and the difference is the amount of load that they impose on the circuit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425538 30th Jan 2017 7:15am
Thanks for your thoughts , I didn't think of can bus problems Censored I don't know how little resistance these CREE bulbs create
I have now ordered some error free to see how that goes Thumbs Up
Edit; that picture is crap sorry Embarassed 2008 MY Supercharged
Post #425568 30th Jan 2017 10:07am
miggit
Shocked That's a picture...... Rolling Eyes I thought it was a fancy full stop Rolling with laughter Rolling with laughter
You of all people should know how fussy the LCM can be and all the hissy fits it has when it's give LED's to monitor... seeing as a normal bulb works and an LED doesn't it can only be a lack of load that's Censored up the system... Just think of a ffrr as a three year old.. no matter how much you try to help them, if they don't want to do it... it's a temper tantrum, dummies spat everywhere and all the toys thrown out the toy box Evil or Very Mad
Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #425724 31st Jan 2017 7:01am
