Home > Technical (L322) > new 'alsmost' owner & steep learnign curve
aspen
United Kingdom 2005 Range Rover Vogue Td6 Epsom Green
HI All,
very new to all this, And i have a couple of questions already. Laughing
1st one, does the TD6 use any coolant, or should this be a concern. Just been to look round a 2005, main dealer maintained vogue TD6 with 137k on the clock, and i notice the coolant level is about 2cm from the bottom of the expansion tank. All plastic bits inside are nice and clean and the coolant is nice and red but would you expect it to remain full between services?
next one, i tried to pair my iphone 6s with the touch screen nav unit and it said no phone installed. Does it have bluetooth as standard, or is that something i'd need to add. If the latter, how long winded and expensive is that to do?
i realise this is my first post, but it will not be my last. I hope to be an avid and useful member of the family very soon Smile
Any input hugely appreciated
Post #425257 28th Jan 2017 6:21pm
aspen
omg my spelling, sorry i should have checked it first.
one more thing, the engine was stone cold and when i opened the coolant reservoir lid there was a notable hiss of pressure, is that normal too on the TD6?
Post #425258 28th Jan 2017 6:28pm
It will say no phone fitted if there isn't one paired.
Try searching on your phone and see if it finds the car - the code will be 2121
Post #425259 28th Jan 2017 6:55pm
aspen
ah, thank you. ill try that one tomorrow. i could see 'land rover' as a bluetooth option to pair to, but didn't know the code obviously.
Thanks for that. Now on to the next question, i hope it's not a head gasket issue.
Post #425261 28th Jan 2017 6:58pm
Try the search function - there seem to be a few relevant threads Thumbs Up
Specifically http://www.fullfatrr.com/forum/topic18450.html
Post #425266 28th Jan 2017 7:11pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
A TD6 should not use any coolant, but its not unheard of. I needn't be a big issue - in fact the most common problem is quite easily fixed.
The coolant expansion tanks have been know to develop a split, which often only leaks at working temperature and pressure. That can make it quite hard to spot - typically you're looking for coolant when the engine is cold and/or the cap is removed. There might be telltale signs of dried-on coolant as a light-coloured powdery material. If it's only the expansion tank, the good news is that they're easy to fit and pretty cheap.
Of course it could be anything else that normally causes coolant loss - a leaky radiator or hoses; a leaking head gasket, even a cracked block. Only a compression test will rule out the the expensive ones.
Your definitely right to be questioning this if you're thinking about buying this one. It could be a way of knocking the price down and turn out to be a cheap fix, or it could be a sign of one to avoid. Compression test before committing would be my advice. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #425283 28th Jan 2017 8:02pm
aspen
sorry.... I have been schooled Smile
Post #425304 28th Jan 2017 9:06pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Hi and welcome to the fold. You will find answers to just about every question you can think of here, or members that can point you in the right direction. I can guarantee you will have a great time with an ff - and probably learn a lot about how they work at the same time...... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #425306 28th Jan 2017 9:23pm
