Home > Technical (L322) > Positive battery terminal |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
The trouble is, the +ve clamp also incorporates something else (not sure what) and is a single piece to alternator and start motor, so not as simple as replacing it with an ordinary battery clamp. The replacement cable is part no. YMS500340 or LR012380. An expensive battery cable! I'm not sure it would be a good idea to graft clamp to the existing new cable - I'm sure it would be possible, but you'd want to be very careful about getting a very low-resistance joint because of the high currents involved.
28th Jan 2017 8:02am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Does ithe cable have the battery disconnect unit on the later models which fires off after a crash ? |
28th Jan 2017 8:25am |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Cheers Steve
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Make sure it is pushed right down on the post. If it is even slightly up it won't tighten. John
28th Jan 2017 8:30am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8611 |
As above, but if yOh are attempting to fit a bigger battery then some fettling is needed. There is nothing that can't be fixed with a hammer😜😜
28th Jan 2017 8:35am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hold on there.... the Range Rover +ve terminal is an explosive coupling and part of the air bag (safety, not EAS) system. I would be very careful about removing it... for a kickoff it will be monitored and as such removal may throw up a fault with the airbag system... I would have a go at getting it to clamp up properly first...
The +ve clamp has a box like thingy on it, and a couple of more wires.
28th Jan 2017 8:38am |
The box type thingy is the explosive type thingy as mentioned above by miggit and can be sensitive and throw an SRS fault.
28th Jan 2017 8:58am |
Your hitting a small bomb with a hammer..... what could possibly go wrong Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
28th Jan 2017 9:01am |
Right start from the beginning........
28th Jan 2017 9:09am |
28th Jan 2017 9:22am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
This thread needs a photo for useful advice to be provided |
28th Jan 2017 9:28am |
I've found this for the BMW... which is basically LR up to 2005, and Ford didn't change everything so I imagine that they are still these.
28th Jan 2017 9:30am |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 |
Or
28th Jan 2017 11:09am |
