Home > Technical (L322) > STEERING ANGLE SENSOR
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I have the Three Amos on my dash board and have been told its the steering angle sensor, is it a hard job to replace the sensor?
Post #423513 18th Jan 2017 4:08pm
First thing is to get it checked with diagnostics, you can get live info from it to see if it is working, changing it means removing the upper steering column from the joint just the engine side of the bulkhead, you then remove the lower part of the column and change the sensor, it's like a donut and encircles the column, it's a bit of a faf to do and it helps if you have someone to help getting it back on, pushing the column from inside the car and lining it up from under the bonnet is a bit difficult on your own.... Download Rave from the WIKI it tells all... If some Censored has been there before and rounded off a bolt your dash will end up looking like this.... You should be able to do it by just removing the black plastic panel above the pedals and use a long extension with a wobbly on it... Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #423636 19th Jan 2017 12:46am
Simran0211
Oh my God 😩
Post #423780 19th Jan 2017 3:38pm
He's just showing off Laughing .
Post #423818 19th Jan 2017 6:03pm
Bluegreygreen Rangie
Australia
Dont' be put off by the picture, you don't have to remove a single dash component. You need a tool like the Gap to re set (calibrate or re set from memory) the new one though before it will work
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #424440 23rd Jan 2017 5:21pm
Simran0211
Cheers Dave Bow down
Post #424451 23rd Jan 2017 7:05pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Also could be one of the ABS sensors. Changing Steering agle sensor is 30 minutes under the bonnet, perhaps at the steering sensor you have only to Change the black ring..., so you have not to learn it. Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #424487 23rd Jan 2017 9:20pm
