![]() | Home > Maintenance & Mods (L322) > TD6 Turbo leak & loose connectors in engine bay? |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 ![]() ![]() ![]() |
Hi guys, got oil leaking from the intake side of the turbo, fair bit seems to have come out although since I changed the crank case filter it doesn't look to have been getting any worse, engine has 142000 miles on it, is it just a case of new seals for the turbo or is it better to get it reconditioned at this stage? also any recommendations as to where it can be reconditioned?
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The loose connectors are for the optional diesel cooler fan, usually fitted to vehicles in hot climates but not fitted to our FFs here in cold Blighty. |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Dont know if they do Rangeys but I just had a Sprinter turbo done by AC Turbos in Skelmersdale after a recommendation. Cracking guys, know their stuff. Very helpful and quick turnaround by post. 2007 Vogue TDV8 with 255/55/20's fitted |
