![]() | Home > Maintenance & Mods (L322) > Sticking front caliper |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
If you continue to get problems then you could try lubricating the piston. You can use a silicone lube - it must be silicone as the rubber piston seal can be damaged by WD40 or any petroleum deriv'
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011
Had a sticking rear caliper, just worked the piston a couple of times, and has been fine since. |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Caliper is working perfectly today, another job I can tick off the list |
