Home > Technical (L322) > Odd Air suspension issue
Brian
Last week all was normal and I parked up. came out in morning to find front right suspension lower than the rest, took it to my local indy and his computer showed no reading in the height sensor. Assuming then new sensor needed so ordered one and cut to today and had new sensor fitted but when we look at the readings the front right shows -15 and no matter what settings we try it won't sit right
we tried to re-calibrate but it always shows a - reading on the front right and there are no other error codes showing
any suggestions?
if we enter the ride height on the computer (as per the diagram I found here) the computer says "suspension calibrated" but it just sits there - I will admit I don't know much about the computer side so maybe i'm missing something?
will get another look tomorrow
Post #422221 11th Jan 2017 5:29pm
The dealers sell a part loom for the sensors, the plug with a length of the wire for you to splice in, very common to have a break in the wire....
A continuity test will show if that's the problem.. Thumbs Up Pete
Post #422229 11th Jan 2017 6:41pm
Macca
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Agree with Haylands, had similar issue turned out to be a broken wire Thumbs Up D3 TDV6 SE 2006
FFRR TD6 Vogue SE Overfinch 2006
RRS TDV6 HSE 2007
FFRR 4.4 TDV8 Overfinch 2012
Post #422239 11th Jan 2017 7:12pm
Mine has been like that for years, no faults, but will always be @ 10mm lower on one side than the other. Learnt to live with it. .
Post #422242 11th Jan 2017 7:38pm
