![]() | Home > My Range Rover > Playing with HDC in the snow - With Vids |
Went out first thing this morning in the fresh snow for a drive around. There is a really steep hill locally which is always a bit of a challenge to get up, but coming back down is often harder work.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Did much the same today except I also had it in Terrain Response Snow & Gravel and manual Gears. |
Need video's next time Gaz. ![]() |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 ![]() ![]() ![]() |
so how many times did you change your pants |
I had every confidence in the car's abilities from previous experience. Playing with the car in safe environments lets you experience its limits and how it behaves whilst at the edge of those limits! - and it does have them! ![]() |
in HDC you do not need to touch the brakes at all.... I have been driving for days in the snow using manual gears and selecting 1st to slow down and HDC on hill so have hardly touched brakes at all which is a good job ! |
scene247 Member Since: 16 Sep 2010 Location: London Posts: 126 ![]() ![]() |
Gazellio, agree on the brake front and didn't use mine either. Still have my foot covering it though as need to stop at the bottom |
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
my hdc makes a noise, is this nornal ? |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
David - YES that is normal, it's the sensors triggering the ABS to make the brakes work.
Tim, where is this info from? I've found no reference to it... My understanding is that the HDC maintains the speed at which the vehicle is currently travelling (upto 22 mph) unless the vehicle is stationery in which case the speed is limited to 2-4mph depending on which gear you are in. 5 wheel rotations would be about 5M ish? I'm sure HDC kicks in before then if the car is already moving. ![]() |
i forgot it was on once having pressed the button accidentally but was able to pull out and accelerate onto a main road albeit with a first gear feel. I switched it off quite quickly but it did not stop me accelerating. |
It doesnt disable the throttle... you can still drive normally its just as you take your foot off the throttle it will then try and slow you down - upto 22mph. ![]() |
