Home > Maintenance & Mods (L322) > L322 remote start
Think that was me Stan......
Have noticed that the fans shut down when you unlock the car...... so it doesn't work if you turn it on the. Unlock the car and forget you did.
Ok so have been and checked, after 10 mins on a frosty start the inside temp was 13.5 degrees at head level, So you are looking at about 1 Deg per min increase i reckon another min or 2 would have that up to 15 degrees plus.
Ok so that might not be "toasty" but it is an acceptable increase and running it over 18 mins would be pointless as you will hit a good temp after that time from a frosty start. Ok so that's not great if it's -10 but it rarely is in the U.K. There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 30th Dec 2016 12:30pm. Edited 2 times in total
Post #420138 30th Dec 2016 12:07pm
deleted my remark Mark.. Wink ... - .- -.
Post #420139 30th Dec 2016 12:16pm
Rambles
The battery management changes
Reduced the cycle from 30 minutes to 17/18.
LR view is that 17/18 minutes is generally enough in U.K. climate to make the cabin comfortable for driver.
The reduction in cycle time was to avoid flat batteries and cars not starting.....
IMHO the full 30 minutes on my old MY10 was better....properly left the cabin toastie for both front and rear occupants when they got in. And particularly on the really cold mornings when you really wanted it.
According to weather forecast the next week or so will see overnight temps down to -4 or so...
Post #420174 30th Dec 2016 3:48pm
Berty
England 2012 Range Rover Westminster 4.4 V8 Baltic Blue
iMO there should be a choice on the cycle times i would sooner take the 30 minuites and make sure my battery was up to the job 👍
Post #420185 30th Dec 2016 5:00pm
Rambles
Berty
+1
Post #420204 30th Dec 2016 6:08pm
Rob99
Mine doesn't seem to get anywhere near toasty or 1deg per minute.
Only seems to be just enough to not be shivering without a coat and vents only seem to be blowing barely above cold, certainly not what I consider warm air Sad
How do you check if it's working correctly? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #420293 31st Dec 2016 12:27am
Rambles
Rob
+1
17/18 minutes gets mine Luke warm.
Takes about 7 minutes before the FBH starts to produce warm air on mine.
And mine is working correctly - it has been tested by a team from Gaydon.
Overnight Temps on the south coast in the next few days are forecast to be down to -5 or -6.
At these sort of temps a full 30 minutes is required.
Post #420475 31st Dec 2016 9:01pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
brrrrrrr glad my cars are parked in a heated barn all night !
Post #420477 31st Dec 2016 9:02pm
Rob99
Lucky cars.... Very Happy 2021 D350 Fifty Edition - Carpathian Grey
Post #420493 31st Dec 2016 10:27pm
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
all my cars have Clifford with intelistart.
Post #421516 6th Jan 2017 10:00pm
forrey
Canada 2009 Range Rover Supercharged 4.2 SC V8 Java Black
Would like to see a video or actual pics of this on a l322 ? Think this is just tempting people to buy the product to find out it does not or will not work ..
Post #422206 11th Jan 2017 4:32pm
forrey
Forgot to put in Clifford remote start .. sorry😳
Post #422208 11th Jan 2017 4:33pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Doesn't the FBH work better if you turn all of the heater controls up to max? 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #422231 11th Jan 2017 7:48pm
I never use the FBH -my remote control is in the safe.... All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #422233 11th Jan 2017 7:52pm
