Home > Technical (L322) > rear washer has a mind of its own
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
Hi again guys.....another little thing id like some help with from those that know their onions...
When i turn on the rear wiper it wipes as you would expect, but the washer jet works when it feels like it...it doesnt matter if i hold the stalk in the wash position or blip it 1,2,3, 20 times, it just sprays a jet, may be two when it wants, its not leaking out before it gets to the jet, i can hear the pump running only when it actually sprays ....apart from this being a pain in the rear .....its wearing out the rear wiper blade as it does four or five sweeps before it gets any lube and we have a hell of alot of salt being thrown about at the moment.....
Is this usual or is someting amiss.....
cheers..
Post #420287 30th Dec 2016 10:49pm
proser
Maybe the non-return valve is not doing it's job and over time the washer fluid runs back to the bottle. Had this on mine until it was replaced. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #420288 30th Dec 2016 11:01pm
billsmith737
id almost agree, but, the pump just doesnt run....when it decides to it washes instantly.....its as if it has its own delayed time system......if it has...its crap!
Post #420314 31st Dec 2016 2:09am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
mines the same thinking of having a separate washing system put on
Post #420315 31st Dec 2016 2:16am
