Home > Wheels & Tyres > Tyre wear.
stwid
Tyre wear.
Hi All.
I have a 2004 4.4 V8 Vogue. The rear tyres are wearing on the inner edges on both sides of the car, is this correct. In the past I have had several BMW`s that wore the inner rear edges and was told that this was correct. Is this the case for these has they were owned by BMW?
Any advice would be a great help.
Stuart.
Post #423010 16th Jan 2017 10:31am
proser
I would suggest that you get a full alignment done, which can also check rear camber. Some of the kwik fit centres have the equipment to do this. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #423014 16th Jan 2017 10:57am
..and they will be able to tell you if any bushes have had their day...
Post #423017 16th Jan 2017 11:22am
CS
I had a 2004 4.4 for over nine years and didn't have that, so agree that your car should be checked/sorted. Only Range Rovers since 1988
Post #423039 16th Jan 2017 12:23pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
07MY, my rears wear on inner edges too. Maybe an alignment is due Rolling Eyes Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #423061 16th Jan 2017 2:05pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Definitely needs an alignment. Dont go to kwi fit though, go to one of the few centres that have the corect Hunter machinery for a complex beast like the FF.
Here's a list of them:
www.alignmycar.co.uk NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #423080 16th Jan 2017 3:50pm
proser
Kwik Fit have either the Hunter system or similar so can provide the same type of checks that the FF needs. Regards
Mark
2012 Westminster
Post #423081 16th Jan 2017 3:54pm
Sandyt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
If you go to a kwikfit centre with the Hunter system they do a deal for four wheel alignment if you sign up think it was 99 quid for 4 alignments in a year I need at least two as I change from winter to summer and back again
Post #423088 16th Jan 2017 4:38pm
cass
I never used to be a fan of the likes of Kwikfit but as the tools become more automated and idiot proof(ish) like Air con servicing etc. they seem to offer pretty good service.
I recently had the alignment checked on a Hunter machine at a Kwikfit after I had fitted a track rod end, as they charge for each adjustment they have to make it would have cost me about £60 or the variation on the above offer was as many checks/adjustments as you need for 2 years for £100.
Given how rapidly our cars eat suspension parts I expect to get my monies worth out of them.
So far I can't fault the job that they did and you can see exactly what they are doing on the screen.
Post #423095 16th Jan 2017 5:05pm
Sandyt
Yes that was the deal couldn't remember but for 100 quid it was spot on
Post #423097 16th Jan 2017 5:10pm
stwid
Hi all,
Thanks for the information I will try and find someone with Hunter equipment. We do not have a Kwik Fit over here only ATS, National Tyre's and a few independents, not even a Land Rover dealer.
Many thanks.
Stuart.
Post #423233 17th Jan 2017 10:19am
