![]() | Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 Alternator Replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
have you seen this from our wiki?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Not sure how the access is from the bottom. Looking at the top of the engine to check my pulleys the other day taking the fan off is a PItA, according to rave the whole surround has to come off. However if the alternator will go out downwards then the belt tensioner can be accessed just by removing the top turbo hose, which gives good enough access to release the belt. I would suspect most of the fan removal malarchy is to do with getting the belt off, which isn't 100% necessary.
K8DJK Member Since: 08 Nov 2012 Location: Lincolnshire Posts: 10 ![]() ![]() ![]() |
Thanks Guys,
Good evening all,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
Thanks - mine will undoubtedly need doing but hopefully not for many years yet. |
Well done that man!!
AJL322 Member Since: 08 Nov 2019 Location: Inverurie Posts: 22 ![]() ![]() ![]() |
Hi, good read. I did the alt in my old 2008 range rover on a drive in the snow and was a total PITA.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Welcome and search really is your friend here.
Thanks for getting back to me. Had a look over the post and looks like the tensioner alone is an easy job, unfortunately my belt is running about half off the tensioner and I think it has been rubbing against the fan pulley. Be fair the car just hit 100k miles so would need done anyway. Just cant see how the cover would come out without major work??? I will try do a search on here to see what info there is or try the method at the end of the post.
Love the rant, well after the ribbing |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I now get constant ribbing at work for owing a rangie
yeh I believe its jealousy too! its not always broken, I just like to keep her well maintained! |
Must admit I was sucked into this 'you'll always be paying out for this that and the other' followed by 'I wouldn't touch one of those if you pleaded with me'.........so you've never had one eh? You've listened to gossip down t'pub in t'snug & Fred's mates brothers auntie works in a garage.......... |
Haha, yeh that's how it goes. Everyone that slates them has never had one. |
