Home > Wheels & Tyres > Stowing the Spare - 255/55-20
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
A quick question, with (hopefully) an equally quick answer - does anyone know if a 255/55-20 wheel/tyre assembly fits into the spare wheel well on a L322??? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #417390 10th Dec 2016 3:10pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Yes. Mine has this size and i have a full size spare 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #417391 10th Dec 2016 3:17pm
Clivefog
Yes it does and it is made a lot easier with the webbing strap thingy.
And there is still room to stow a few parts.
Post #417408 10th Dec 2016 5:38pm
Spooky
'Webbing strap thingy' ... Laughing
Not sure what that is - mine don't have one! Regards,
Mick
Post #417410 10th Dec 2016 5:48pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Think he means the gizmo on the earlier ones that would lift the spare out of the cradle for ease of access. Unlike the later ones that you get a hernia lifting out. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #417411 10th Dec 2016 5:53pm
mogman50
England 2008 Range Rover Vogue SE TDV8 Tonga Green
Well I must be doing something wrong then.
My General Grabber 255/55/20 will not fit in the spare wheel well without being let down.
Do some tyres have a bigger rolling circumference then?
Paul
Post #417428 10th Dec 2016 8:30pm
p38arover
Australia
I have a 255/55R20 spare, fully inflated. I wouldn't try to lift it out without the lifting rig that uses the lower tailgate to do the work. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #417435 10th Dec 2016 9:23pm
holidaychicken
My 255/55/20 Pirelli scorpion fits in inflated, the diameter should be 55% of 255mm x 2 + 20" but I think the grabber has a deeper tread so maybe the calculated diameter is based on a bald tyre?
I used the webbing strap thing to remove the spare by hand for ages until I read up on how it latches over the lower tailgate.
Post #417680 13th Dec 2016 1:40am
holidaychicken
Hang on, can't edit my post from my phone, I think I might have 255/50/20, will check
Post #417682 13th Dec 2016 1:56am
jonnyboy54321
My oversized 20" Scorpion'd spare fits too, although is a bit tighter than when on standard tyres. 2007 Vogue TDV8 with 255/55/20's fitted
Post #417818 13th Dec 2016 10:38pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
255/55-20 scorpion just fits when fully inflated but it is a bit tight. The correct size 255/50-20 fits better as it is 1" diameter smaller. 4.4 TDV8 Vogue Baltic Blue MY11
Post #417827 14th Dec 2016 12:19am
Elvis1
United States 2008 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I just fit a fully inflated 265/50-20 Nitto Terra Grappler G2 in the spare tire well of my '08sc without issue.
Post #418585 19th Dec 2016 6:39am
