Home > Maintenance & Mods (L322) > Glow Plug Removal
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Glow Plug Removal
I've got the "Glow Plug Relay" fault coming up on the IID, which from a search and read of Wiki on here seems to indicate I have some dodgy glow plugs. The car is starting all right, and after reading the Wiki and what seems to be the inevitability of snapping off the plugs as they are removed, I'm no hurry to tackle the job Shocked
BUT - is there a surefire way of removing them without snapping any off ? Is there a tool I can buy/hire ? Should I just take it to an Indy to get the job done ?
And glow plugs themselves seem to vary in price a lot - from £14 for a set of 6 from a Land Rover independent, to £60 for a set of Bosch ones Rolling Eyes Any issues with the cheap ones ??
Post #415475 26th Nov 2016 5:52pm
I gave up in the end Big Cry
Here is a youtube for the Laser Tool Set if you fancy doing this six times with the head in-situ (or ruining your head!). More expensive tools provide for tying/locking to the head for accurate drilling.
Worth checking what your Indie will charge for doing all this.
That said, in our climate, even when very cold, glow plugs don't make much difference. I only have three working now, an FFRR still starts just fine on a frosty morning. .
Post #415517 27th Nov 2016 1:40am
If it starts and runs fine then leave well alone, they can be a right PITA to change
In my 5 years of owning a TD6 I used the glow plugs on two occasions when the temperature dipped to -17°C
Post #415530 27th Nov 2016 8:46am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
The relay is however cheap and easy to replace, so you could of course try that. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #415534 27th Nov 2016 9:22am
Biffo
"Leave well alone" seems the best advice Laughing
Has any one used the tools that vibrate the plug loose, and are they any good ?
Post #415578 27th Nov 2016 1:29pm
G62
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Being down to 1 working glow plug and dreading breaking them on removal I invested in the air tool that vibrates them out. It works like a charm. All six out and after 220 k km service. The worst one needed 4 minutes of vibration at 20 Nm before it surrendered. The job was done in just over 1 hour.
Since then I have used the tool on a number of rusted nuts and bolts, works great.
Post #431444 16th Mar 2017 9:47pm
Biffo
Thats good to know ! I'm taking my TD6 off the road at the end of this month and have a list of things to do including injectors, so I think I'll invest in the tool and have a go at the glowplugs as well.
Thanks Thumbs Up
Post #431470 17th Mar 2017 9:38am
naks
South Africa
One of the local indies won't even attempt to remove glow plugs without the car running a few days with 500ml of 2SO in the tank. Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
Defender Puma Workshop Manual: http://1drv.ms/1nNpJeM
Range Rover/Sport Workshop Manual: http://bit.ly/2iH7jgG
Post #431471 17th Mar 2017 9:50am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Would you care to share details of said air tool please?
Post #431473 17th Mar 2017 10:04am
G62
Sure, there are several picks on ebay, I did some research and end up with this one
http://www.ebay.co.uk/itm/Werkzeug-Impact-...SwLVZVmGJA
They come cheaper but this one seemed a good balance between cost and quality. Very happy with my investment.
PS Just as for getting out injectors it is important that engine is warm when vibrating out glow plugs, I let it get normal operating temp before I started the job. I did not use any additives in the fuel in advance, just a little dash of my favourite penetrating oil.
Post #431492 17th Mar 2017 1:57pm
