![]() | Home > Technical (L322) > Battery drain or new battery? |
Is the drain of 0.18A on the earth after the car has fully gone to sleep ie after about 20minutes? |
countryboy Member Since: 05 Aug 2014 Location: Reading Posts: 37 ![]() ![]() |
The drain was on earth just after unlocking the car which had been sat unused for hours. 2007 RR Vogue SE TDV8
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 ![]() ![]() |
You need to measure the drain appr 20 minutes after you've locked the car - or closed all doors. You can do this by stripping the bonnet sensor so that you can open the bonnet without the alarm going off. Imo you should try to sort out any drain before replacing battery.
When you open the car quite a few ecu's switch on which is the current you are probably measuring.
OK.
Your car probably has a minimal drain anything up to 30mA, so your battery will show a small drop in voltage after 7 days.
Makes sense, so dropping 1.4v in 5 days is probably saying the battery isnt holding charge and needs replacing? 2007 RR Vogue SE TDV8
Could be the battery but could also be a battery drain.
OK will do. I've just tried to start the car (batt 11.7v) and nothing at all - whats the min voltage for start? 2007 RR Vogue SE TDV8
One thing to consider when you open the car the battery voltage will drop, particularly if you have the radio on. You really need to wait with the door open until everything shuts down and the battery voltage recovers to a stable reading to measure it.
