Home > In Car Electronics (L322) > battery drains down if car not use every couple of days
Rambles
20 milli amps
Is the FFRR standard. Below this and Land Rover will officially say you're ok.
0.19 amps is nearly 10 times this amount.
Post #415783 29th Nov 2016 7:06am
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
i have carried out a few things in trying to find this bat drain when the cr is not used for a few days; i have removed the blower fuse as suggested, but woulden't say this proved anything one way or another really so i want to check the battery condition and see if it looses power on its own;
my idea is to charge it over night then take a reading over a few days to see if it drops etc; but could i do this without taking it off the car ,? ie by just disconnecting the earth, would that be ok or would i need to also remove the positive connection?
i dont have a clue as you can see, but at least im honest aye Embarassed Embarassed Rolling Eyes
bob
Post #416884 6th Dec 2016 3:24pm
