Home > Technical (L322) > christmas tree faults |
From your description I would look at the very basic things first. Those faults might be sporadic but the general conditions you describe could be something as simple as a bad earth. That "Christmas Tree" scenario is normally because the voltage supplying the various ECUs drops low and causes one or more of the ECUs to reset.
24th Oct 2016 2:43pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Generally when the transfer box joins in with HDC faults it's power related... normally lack of, caused by duff battery, so a rotten earth connection could be the source..... And I thought that those faults had died with the Defender, looks like Land Rover have retro fitted them to the Range Rover for old time sake Yesterday I couldn't spell Engineer... Today I are one!
24th Oct 2016 3:01pm |
alangrig Member Since: 03 Jan 2016 Location: Riga Posts: 26 |
Thank you very much, appreciate. BTW, battery is newly fitted last winter and occasionally on start the message pops up on screen: reactivated suspension. |
24th Oct 2016 3:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8542 |
as above, the easiest place to start is the battery terminals. Then move to earths.
24th Oct 2016 3:25pm |
Thank you! |
26th Oct 2016 1:48pm |
The issue is solved: the problem was related in high pressure pump PCV Valve. Indie flushed it away with brake cleaner several times. For the last 3 months no issues so far.
24th Apr 2017 4:36pm |
L322Dino Member Since: 16 Apr 2017 Location: Ligne de Maginot Posts: 5 |
Photos the pcv valve ? |
24th Apr 2017 6:50pm |
Dear All,
19th Dec 2018 10:25am |
