Home > Wheels & Tyres > Tyre damage inside wall |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Just got home towing the caravan and when I got out of the car there was a loud hissing from the rear nearside tyre.
23rd Oct 2016 4:07pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35361 |
check the production date, it might be an old tyre cracking up.. ... - .- -.
23rd Oct 2016 4:19pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8257 |
Looks to be a bulge in the tyre up towards the G and the O, or is it just the camera angle... in which case it would indicate damage from hitting something fairly substantial... Pete
23rd Oct 2016 4:32pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1431 |
Have you been driving through any ruts......looks like that would slice the inner wall if there were something sharp in the rut.
23rd Oct 2016 4:36pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Pinched it between rim and a kerb perhaps? Old tyre will show cracks between tread. |
23rd Oct 2016 5:11pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Speed bumps at speed? Especially the type that are not the full width of the road, as these will pinch the inside of the tyre. Worse on low profile tyres. |
23rd Oct 2016 5:22pm |
Looking at it again you can see between the two red arrows where the tyre has been squashed against the rim and wiped the dirt off...
23rd Oct 2016 5:27pm |
I think the clean bit is where I have rubbed it when feeling for the escaping air.
24th Oct 2016 8:05am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Looks like damage from under inflation, what pressure were you running it at for towing?
24th Oct 2016 2:30pm |
^^ That rather depends on how the van was packed and how much was packed into it If your not careful it is possible to put a lot weight on the rear tyres without it showing too much, because of the self levelling nature of the suspension.... it's only the bulging tyres that give it away Yesterday I couldn't spell Engineer... Today I are one!
24th Oct 2016 5:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8597 |
indeed. you need 7% of the vans MTPLM on the nose, which is realistically impossible to judge and daft in larger vans. My van has a max weight of 1895kg which means that the nose should be 132kg. which is stupidly high and will damage the caravan. In reality a nose weight of around 90kg is sensible.
24th Oct 2016 5:44pm |
We don't know what the load rating on those tyres is, all I was saying is it's possible to increase the rear tyre loads without realising it, cos the car don't drag it's butt when it's loaded, too much, which we wouldn't do would we
24th Oct 2016 6:42pm |
There is nothing that can't be fixed with a hammer😜😜
24th Oct 2016 7:00pm |
Took the car into the local kiwk fit yesterday and the manager had never seen anything like it, they put it up on the ramp and the other tyres were fine.
25th Oct 2016 8:51am |
