Home > Maintenance & Mods (L405) > Air Suspension Compressor Blocked - Q590
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi
Just wondered if anybody else has had or knows about the "Service Action" that is needed for the Ranger Rover and Range Rover Sport vechicles.
I have just had mine for its 2 year service and I saw on the TOPix site that this was needed. I contacted Jaguar / Land Rover and quoted my vin number and I had confirmation back that is it on the recall.
It is not dangerous but could affect the air suspension . The action is referenced as publication no. Q590
"At the next service opportunity you are requested to inspect air suspension compressor - if no white resddue is coming from the exhaust silencer replace air susoension sintered silencer and update software. If white residue is visible replace compressor and update software."
Anybody had this carried out or know anymore infomation
Thanks
Mariana Black
2014 Autobiography 3.0
Post #408862 11th Oct 2016 7:58pm
Mikey
Nice to see they learned their lessons from way back in 2006... Rolling Eyes
Post #408883 11th Oct 2016 8:56pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Anyone know the chassis range for the L494 please? Got this exact issue with a recently purchased SVR that throws the amber warning and locks out the height adjust, diagnosed as a blocked silencer
Post #535515 26th Nov 2019 1:59pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
That is an issue with the air dryer allowing moisture to pass through the system and clog up the exhaust. Remove the silencer and replace the drying material, replace the silencer. I haven't looked at the compressor on my 405 yet, but this was the process on the l322. Replacing the entire compressor may not be necessary.
Post #535555 26th Nov 2019 7:54pm
carlos50
Do you have any instructions please, which bit is the air dryer, the bung in the line?
Post #535556 26th Nov 2019 8:04pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I've always thought the ride quality in my L405 is nothing better (indeed probably worse) than your average car. Never had any suspension warnings crop up, and the strange thing is, at times I think it rides reasonably well, but other times every pothole and drain cover I drive over is a major obstacle. I'm on 22 inch wheels which doesn't help, none the less it ought to be better than it is. Any thoughts ?
Post #535557 26th Nov 2019 8:11pm
brad s1
I have not looked at the l405 setup, but on the l322 it was a canister fit to the side of the compressor... it removes moisture being drawn into the system and again before air is vented to atmosphere. When it begins to fail it'll allow moisture into the system resulting in the vent spitting liquid and then eventually clogging to the point suspension commands to lower fault. Again... not sure how it is exactly setup on the l405 but it cannot be too much different. There still must be an air dryer and exhaust somewhere on the compressor unit.
Post #535558 26th Nov 2019 8:13pm
brad s1
That is because of the 22" wheels, they have no business being on an suv. If you drop down to a 20 it'll ride more like a range rover should.
Post #535559 26th Nov 2019 8:16pm
roberlar
I suspect you're right. My previous 322 was a much smoother ride on smaller wheels. Bought the 405 with the 22's so maybe a change is the solution. I ought to drive some different combinations to see.
Post #535562 26th Nov 2019 8:28pm
GGDR
L322 rides better because heavier?
Corners worse but possibly rides better.
. Cheers, Greg
Post #535580 26th Nov 2019 10:34pm
brad s1
My 405 with 20's rides better than my l322 did with 20's. I never put 22's on the l322 but I'd imagine it'd ride like crap with them.
Post #535590 27th Nov 2019 3:25am
