Home > LPG > What spark plugs
mattyp
What spark plugs
I want to change the spark plugs on my 2003 4.4v8 with lpg.What do people recommend?
Post #408237 8th Oct 2016 7:51am
Dolphinboy
Matty, there are a few posts on here ref this. The most knowledgable contributors say go with the normal regular ones and don't waste money on titanium or whatever the "special" ones are are made of.
Post #408267 8th Oct 2016 11:40am
What flipper said... bog standard NGK's are the best IMHO, I've tried them all over the years... certainly don't waste money on the so called LPG plugs, it's just a con to sell them....
Thumbs Up Pete
Post #408385 9th Oct 2016 12:35am
mattyp
Thank you I'll get the standard ngk plugs for it
Post #408397 9th Oct 2016 6:55am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I can give you a heads up on this one, I have been installing LPG for some years, the best spark plugs I have found upto now are call BRISK you will find them on the evil bay and similar, thay are advertised as LPG plugs to, they are not a premium price but do run very well, I have had many car's running these plugs
evil number eBay Item No. 370581263277 seller is WTV they come in at £38 a set delivered
Post #408518 9th Oct 2016 8:05pm
I tried Brisk in a Disco a few years ago... ran fine but didn't last anywhere near as long as NGK's... Also found it's not so important with modern distributorless ignition to use fancy plugs, the coil per cylinder arrangement means the spark is big enough for LPG anyway... Thumbs Up Pete
Post #408529 9th Oct 2016 8:42pm
Lukie
brisk offer a few different plugs the one's I linked to are single node plugs, have had them in all sorts of engines with good results
Post #408531 9th Oct 2016 8:44pm
Yep, was the multi node ones I tried, maybe they realised the same issue...
Oh well, NGK or Brisk then... Thumbs Up Pete
Post #408546 9th Oct 2016 9:17pm
Lukie
that would be the difference, multi node plugs are a no-no for LPG the spark can be sometime weakened with multi node plugs always best to use single node where possible, there is quite a few spark plug comparison websites, found 2 company that offer the plugs up, the one listed above is one I have used many time quick service
Post #408668 10th Oct 2016 7:03pm
johnboyairey
I've just got a set of the brisk (silver) branded ones, delivered for £31 from eBay. I'm not going to set a link, but wasn't hard to find them. I've fitted them today, but haven't had chance to drive it yet.
Was having a misfire under load, on the iridium ones, that I fittted a couple of years back, so hoping I've cured it.
Post #408711 10th Oct 2016 10:24pm
johnboyairey
Just to follow up, (see above) it seems my previous spark plugs, (NGK iridium,) which were recommended by my LPG service guy, have lasted maybe 5000, but certainly less than 10,000 miles. (Haven't got the fitted mileage) They were creating a bad misfire, after a decent warm up, and though was much better when switched back to petrol, was still having a few exhaust pops, and slight hesitation, when accelerating. I fitted the Brisk silver LPG type, and car is now driving fine again, both petrol, and LPG.
The new brisk plugs, are single tipped. (Like the iridium)
Post #409312 14th Oct 2016 5:02pm
Lukie
Good to hear the brisk plugs have been fitted to another fine machine, I highly reccomend them as a lpg fitter
Post #409710 18th Oct 2016 8:32am
klf400
I have used standard plugs in both p38 and l322 for the past 12 years with no problems
however i did fit magnecor leads to the p38 Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #411160 28th Oct 2016 6:58pm
friskydog
I have just installed the NGK Copper Core Spark Plug LPG1 (1496) and yes they were pricey. Feeling like I should've done more research after reading this thread. However I will update on how well they do. So far the car has responded better than the old standard NGK spark plugs I had in previously. However proof is in the pudding so we shall see. My car is a FFRR 2007 L322 Vogue 4.2 Supercharged 101k miles. I am running a PRINS VSI 2.0 LPG System with Automatic Flashlube system. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #503378 30th Jan 2019 9:48pm
GI JIM
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Need to do mine soon as well 2003 4.4 BRS system. Not to highjack the thread. What mpg you guys getting roughly? May The FFoRRce Be With You
Post #504128 6th Feb 2019 2:46pm
