![]() | Home > Technical (L322) > 3.6TDV8 vs 4.4 TDV8 - 8 Speed |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Dave
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
I don't like the 8-speed in my 4.4 compared with the rebuilt 6-speed that was in my 3.0 D4 due to too much torque converter slip and requiring too much throttle and resultant engine revs to get moving off the mark faster than crawling. It does however get better economy than my 3.0 D4. I suggest a good drive of a couple of each.
The 3.6 sump has 2 drain plugs and it seems that the rear one often gets overlooked. The rear one drains a reservoir for the turbo return drains and has often been found to be badly clogged which is a possible contributor to the occasional failed 3.6 turbos. The 4.4's oil is drained by removing a hose near the front of the sump but it too has a rear drain plug that also gets ignored.
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
Unnecessary quote removed
Interesting what you say about the 8 speed... likewise ill have to get to a dealer with one for sale and see what i think of the shifting... most reviews rave about the low end torque and "seamless shifts" Very good point noted about the dual sump and drain components , And great info on the later ZF 6 speed.... i would sure change that oil at 80 thousand ks or prior , The ZF 6 speed is a huge step up from the GM box in the TD6 ![]() Dave |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
All the 2010 facelift cars have adaptive dampers, LCD dash, improved soundproofing etc. Can't think of a reason why you'd choose 3.6 over 4.4. |
The CVDs were optional in Oz for MY10 at least on the 3.6, only becoming standard here for MY11/12. An Oz 4.4 owner is about to replace his rear CVDs after nearly 80K kms that included some reasonably hard work and has discovered their significant cost, although cheaper but still expensive after market ones are available. However the ride is very good on secondary country roads and the reason why I upgraded from the 3.0 D4.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
There is no comparison between the 3.6 and the 4.4 and the overall spec of the respective model years, it's like night and day - drive the two back to back and the difference is huge. You need to drive one - that will crystallise the decision for you.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
Other than the 20k reasons already stated ![]() Coming from a TD6, you're going to be very happy with a 3.6 - and yes, the 4.4 is better, but 20k is 20k...... |
I cant seem to do multiple quotes on here... mind oyu i see i put up an unnesasary " one some how, Anyway im sure you will all be watching this thread
Compomotive 18" rims don't fit over the 4.4's brakes. Therefore if needing decent tyres for outback touring then there is only one 19" LT currently available (Maxxis, very recently released) otherwise oversize 20" various brands. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
My 2008 3.6 has the better Brembo set up and as such 18" wheel's won't fit that either, it's not just the 4.4's they don't fit |
Compromotives fit my 2008 3.6. ______________________________
I currently run 20"ATR Scorpions 275/55R 20 , This slightly larger than stock diameter i find means i can have the 20" wheels which although not practice everywhere do suite the large Rangie yet still gives me some proper side wall height for off road type situations. I never really considered a LT tire but the pereilli so far have been fantastic... very well wearing and little to no noise given they are a true AT tire, They have not been off road as much as i would have liked so perhaps i could be very wrong but i do feel they would be trustworthy off the beaten track in the middle of no wear
