Home > Technical (L405) > Nearly lost it...
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Nearly lost it...
Just s##t myself! I'm down at 'fit-slow' having a Kidney removed as it has a nail in it. Anyway, the fitter removed the tyre and then proceeds to cut off the valve!!!...so I runs out about to give him a Censored ( thinking the idiots damaged the TPMS device) and gets there to find no donkeys plonk fitted? Seems the new fatty uses the difference in wheel circumference calc'd by the ABS to suss a puncture rather than the L322's pressure sensor...calmed down now Smile GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #406141 24th Sep 2016 9:13am
I think it's more likely you don't have TPMS fitted..... Whistle
It was still an option in 2013 - and the valves were the same as the L322.
Post #406150 24th Sep 2016 9:44am
ajac8
Is the running circumference not affected by loading? Seems a bit of an unreliable measure for pressure. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #406161 24th Sep 2016 10:58am
paulmoran2
Not fitted? TBH I never thought of the possibility it wasn't fitted. Will have to look into that, but given that I switched the TPMS off on my L322, it's no great loss. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #406164 24th Sep 2016 11:42am
GraemeC
Pretty sure some sort of TMPS (either active like the L322 sensors)or passive (tyre circumference) has been mandatory on new vehicles from about 2012.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #406168 24th Sep 2016 1:14pm
Emperor Mong
My car has pressure sensors.
The ones with TPMS have metal valve stems, the non-TPMS ones have rubber.
The way to check is to turn on the ignition but NOT start the engine. Bring up the menu in the instrument binnacle. Select Service Menu (this is greyed out if the engine is running) and look for tyre pressure check.
Post #406171 24th Sep 2016 3:21pm
mzplcg
^ Yep, exactly. Although BMW use the ABS sensors and it is way more reliable.
Post #406173 24th Sep 2016 3:23pm
paulmoran2
I don't have any form of TPMS. As EM says, rubber valves are the give away but checked TOPIX to be sure and it says LESS TPMS.....so I haven't got the thing I didn't want Laughing GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #406181 24th Sep 2016 4:28pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
It became mandatory in Autumn 2014
Post #406185 24th Sep 2016 4:42pm
