Home > Technical (L322) > .............................. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
1. You can't "bodge" the steering column lock, the solenoid is also a hall effect sensor and the immobiliser needs a signal from it, you need it repaired or replaced..
13th Sep 2016 2:12pm |
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 |
13th Sep 2016 4:47pm |
Hi
13th Sep 2016 5:20pm |
OK I'm not very fluent with the L322 just yet, so excuse my ignorance, Car starts and drives fine now ( with the fuse 18 trick ) AFAIK the hall sensor is in the steering column solenoid and the steering column lock is busted, so what ever it is doing its still sending the right the signals to the ignition barrel pin for it to disengage and release the key pin so it can start. Right so far ? So wheter the SC ECU sends the signal to the ignition barrel pin or not, with the pin not there in my mind it shouldn't make a difference or am I missing something ???? |
13th Sep 2016 8:48pm |
Put key in... immobiliser chip in key talks to immobiliser and allows the key to work... steering lock sends a signal to the steering column lock to unlock, combined solenoid lock and hall effect sensor moves and confirms to immobiliser that it is unlocked, also allows key to turn, immobiliser then tells the engine ECU that it is OK to start...
13th Sep 2016 9:01pm |
Unnecessary quote removed
13th Sep 2016 11:46pm |
It's very easy to remove the pin if you want to try it, download RAVE from the WIKI, remove the ignition barrel and it's pretty obvious how to remove it.... Pete
14th Sep 2016 4:53pm |
Why does that sound like a sarcastic go ahead screw up your car, but I told you so. |
14th Sep 2016 8:46pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
14th Sep 2016 10:46pm |
No sarcasm at all and you wont effect anything else, it means you can turn the ignition on when the SC lock prevents the key from moving but I don't think it will let the engine run, but, as you say, yours maybe different to mine and it may work....
15th Sep 2016 6:05pm |
16th Sep 2016 2:49pm |
Not sure about the missfire, very difficult to diagnose at a distance...
16th Sep 2016 9:15pm |
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 |
4)
16th Sep 2016 9:25pm |
7)
16th Sep 2016 9:29pm |
