Home > Maintenance & Mods (L322) > Rear hub
Stoich
Rear hub
I'm trying to change the dust cover for rear brakes which requires removing the rear hub. I've undone the centre nut and have tried a puller on the hub but it's not budging and I don't want to put too much pressure on hub. Is there something else I should be doing in order to remove hub or should it just pull off once centre nut is removed.
Thanks in advance for any advice. If you like it, who cares what other people think
Post #404057 8th Sep 2016 3:19pm
Weegie
As far as I can see from RAVE it needs a puller to remove the hub.
"16. Fit centre screw LRT-60-030/3 to LRT-60-030/
1 and fit to hub with spacer LRT-60-030/2.
Secure with nuts LRT-60-030/5.
17. Tighten centre screw to press drive shaft from
flange.
18. Remove tools." John
GAP iiD BT
Post #404061 8th Sep 2016 3:39pm
Stoich
I have taken the disc and all the hand brake bits off so all I'm left with is the hub, looks like it should just slide of the spline but it's not happening If you like it, who cares what other people think
Post #404062 8th Sep 2016 3:41pm
Weegie
See above. I was typing at same time as you. John
GAP iiD BT
Post #404063 8th Sep 2016 3:47pm
Stoich
Thanks for that weegie, so there is nothing else holding it on? I guess I need to up the effort on the puller. If you like it, who cares what other people think
Post #404064 8th Sep 2016 3:53pm
You can't pull the drive flange off with the hub still on the car, you need to remove the drive shaft which is an exact fit in the flange and very tight, you then remove the whole hub and get a massive press to press the drive flange from the hub, this will wreck the bearing if you manage to do it. After a new bearing and more swearing It's then a pain getting the driveshaft back in as you have nothing to hammer...
I think there are three or four specific tool JLR use to do this job and I'd say it's neigh on impossible to do it at home without them...
It's a total nightmare changing the back plate...
Best option is to cut the new backplate in half, weld or rivet on two tabs, and put it on in two pieces...
Someone on here did it a while ago and did some pictures... Thumbs Up Pete
Post #404110 8th Sep 2016 9:02pm
Weegie
This thread:
http://www.fullfatrr.com/forum/topic39007....rake+plate John
GAP iiD BT
Post #404111 8th Sep 2016 9:10pm
Stoich
Thanks guys, no wonder I couldn't get the effin thing off. Time to get the dremel out and get cutting. If you like it, who cares what other people think
Post #404243 9th Sep 2016 6:51pm
