Home > In Car Electronics (L322) > Phone wiring in boot?
Danwilderspin
Hi Guys,
my car came with a parrot which is ok... anyway was in the boot looking at the dvd unit for another reason and i noticed a big black plug not connected to anything?? i then notice two kind of aerial plugs next to it... are these prewired for bluetooth? can i just get a unit plug it in and call it a day?
Post #403917 7th Sep 2016 5:00pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
If you are lucky enough to have the pre wiring it isn't too big a job. You'll need a Bluetooth antenna and microphone as well though. Do a search; there's plenty of info on here (or even look on the Bimmernav website).
Post #403922 7th Sep 2016 5:47pm
Zulu 10
That sounds more like the wiring for the (analogue) TV receiver with a pair of SMB plugs.
According to your profile your car is a 2002 model, at which time we were only just starting to hear the term 'bluetooth'.
Post #403923 7th Sep 2016 5:48pm
chris_read
What does the black plug look like?
If it's the 54 pin connector like below it was prewired for non Bluetooth phone but you can use a BMW Bluetooth ulf as long as you check that the plug has been repinned accordingly. As I said, lots of advice on this forum. Try a search for '54 pin connector'.
Post #403975 8th Sep 2016 5:38am
Danwilderspin
This is what's in there
Post #404009 8th Sep 2016 9:04am
mjdronfield
Search for ulf also.
I fitted it to my td6. Don't really want to reiterate the threads again.
Also have a search for "BMW upgrades" as I tried to link various bits from a single post....
It's worth doing imho.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #404072 8th Sep 2016 4:42pm
Danwilderspin
Ok thanks but with what ingot am I half way rtheree ?
Post #404107 8th Sep 2016 8:46pm
mjdronfield
That plug is meant to go into a telephone control module or TCM that our cars had if you had a phone in it from factory. BMW then made the ulf that did Bluetooth and went in the X5 and 5,series etc, but Land Rover was sold to Ford by then, so it never got fitted to any Rangies. They can be retrofitted though. You need to move about a dozen of the wires in that plug so it will work with the BMW ulf. You have the aerial lead on there, so all you need it a Bluetooth antenna, a microphone for the front a ulf and to rep in the plug. Same with a later digital TVs tuner... It's a straight swap with that unit though!
Have a search, it's all on here....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #404118 8th Sep 2016 9:37pm
jaybear
France
Hi
just a quick one ...
Why a microphone if you already have the phone in from factory ??
Just wondering ........... Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #404142 9th Sep 2016 8:29am
mjdronfield
He doesn't already have a phone in there.... That's why the plug isn't plugged into anything. Most of the cars are pre wired for phone, so the loom is there. The connector for the microphone will be there already, but not the actual microphone....
If that makes sense...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #404191 9th Sep 2016 4:08pm
Danwilderspin
Right off the back of what's being said I've layer my hands on a 10th gen module, a Bluetooth antenna and a mic... I see above you say pins must be swapped then it's pretty much plug and play... which are these and is there a diy? Thanks
Post #404392 11th Sep 2016 1:27pm
mjdronfield
It is.... Do a search for ulf. I don't really want to go through it all again. There is no soldering. If you take the plug apart the 2,rows slide apart and the connections are numbered. Use a small screwdriver or bradawl to push the little tag down and you can gently pull the wire out and pop it where it should go.
I bought a new connector from an Audi dealer and just moved the ones across that were needed, used the new plug in the ulf and left the old one dangling.
Others have just repinned the existing one, but don't lose track of where you are.
Job done.
The antenna bolts onto the 2 bolts sticking up above the sat nav frame....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #404402 11th Sep 2016 2:00pm
mjdronfield
The chart is on page 3 of this. Though the new plug etc and other info is at the beginning.....
http://www.fullfatrr.com/forum/topic14122.html?highlight=ulf
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #404403 11th Sep 2016 2:08pm
I did this recently Dan, have a look here:
http://www.fullfatrr.com/forum/topic35589.html .
Post #404406 11th Sep 2016 2:35pm
Danwilderspin
Hi guys just done the repinning and plugged module in then went to do the mic and pulled the cover down but can't find the connector? Any idea where it is - all I can see is the sunroof switch and motor cables?
Post #405222 18th Sep 2016 10:28am
