Home > In Car Electronics (L405) > TV Problem
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
TV Problem
While I'm wittering on about dashcams, I thought I'd post to ask if anyone has had the same TV problem I do.
Yes, they're hopeless on the move and not a great deal better when you stop, but I can't change the channel at all on my 2014 VSE.
It's stuck on London Live for some reason. Everything else says 'No reception' and then goes back to London Live.
And London Live isn't that great.
Yes, I'll take it back to the dealer eventually but I thought I'd just ask.
Can't find anything on search.
Simon.
Post #403064 2nd Sep 2016 3:56pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
try changing settings and change back, sounds like its got stuck.
Post #403076 2nd Sep 2016 5:32pm
Macpaul
I've been out to it and all it's got under TV Settings is Traffic, News and TV Country.
The first two are presumably radio interventions.
I tried changing country but it kept going back to UK.
Are there any other settings I'm missing?
Post #403077 2nd Sep 2016 5:46pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Would removing the relevant fuse not help? (Although you may lose other accumulated info - avg mileage / speed etc) . Thinking if the software had locked up, then removing power may reset it to factory default after a short period or the like? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #409034 12th Oct 2016 2:54pm
Macpaul
That's quite a canny answer that hadn't occurred to me but in the end I took it back to the dealer who beat it with a blunt stick for a couple of days and put it right.
I mean replaced the TV module sir.
Apparently, in early vehicles, the signal went first to the rear screens (if you have them as I do) and via them to the front. Something had broken down between them I was told.
Now the front feeds the backs apparently.
Post #409035 12th Oct 2016 3:00pm
Is it like the old system where it only keeps the channel you last watched and you need to auto-tune every time you park up to watch TV? 2008 MY Supercharged
Post #409096 13th Oct 2016 3:47am
Macpaul
No, you can store up to 12 TV channels, just like in the radio but if you're not within range when you select them, you won't get them, obviously.
Which happens a lot, at least in my part of the southern U.K.
Post #409105 13th Oct 2016 7:49am
