Home > Maintenance & Mods (L322) > Diesel smell
RRSHSEDL
United Kingdom 2007 Range Rover HSE Td6 Stornoway Grey
Diesel smell
Hi,
any ideas regarding a diesel smell I have when is heat up and I get a whiff of diesel when getting out when parked up. I have leaky injector 2 is very slightly leaking i.e. very small amount leaking (very small bubble of diesel) from top of injector when engine ticking over, but I didn't think it may be enough for smell? also I have noticed the fuel cooler radiator always seems to be wet when I go underneath.
1) What is directly above the fuel cooler that could be leaking diesel?
2) Possible that the diesel from injector 2 is dripping down?
3) Could the actual fuel cooler be leaking itself. On this note what are the four pipes connected to the fuel cooler for?
4) The wet patches, seem to be mostly on the drivers side of the engine when lying on the floor looking up that I am assuming are diesel ... any other suspects i could check?
Cheers
Post #350054 30th Sep 2015 10:31am
RRSHSEDL
OK I have taken out injector number 2 and stripped it down and found that the top O ring is bust.
Does anyone know where I can get one to replace this?
Oh and yes if you also know where I can pick up a single leak off retaining clip Thumbs Up
Post #403188 3rd Sep 2016 5:29pm
Weegie
11 months to do that Question John
GAP iiD BT-Sold
Post #403189 3rd Sep 2016 5:37pm
