Home > Technical (L322) > Trans failsafe prog |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
if you search those words on our search function, loads of stuff will come up that will entertain you for the rest of the afternoon... ... - .- -.
24th Aug 2016 11:20am |
missbelle Member Since: 22 Jan 2016 Location: west sussex Posts: 13 |
Excellent thank you lol..... i have had a quick glance and when it does go into gear it doesn't go into 4th as it continues to change up the gears... and i can't check the transfer box as the switch is broken my other half has driven it but sods law it behaved itself while he was driving it so he thinks I've gone mad haha we have plugged it into a snap on verdict machine but its not showing any transmission faults only trans box CAN faults..... |
24th Aug 2016 11:51am |
The display also has air suspension coming up which never goes away just another little problem however when the trans failsafe prog comes up it doesn't stay there like the air suspension it comes up for 10-20 seconds then disappears is that normal?? |
24th Aug 2016 12:00pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Weve now plugged another gear surround in and have no HDC or Hi/Lo actvation only thing that seems to switch off is the DSC, the air suspension problem is Reservoir pressure static when filling, the compressor id an aftermarket one and brand new by the looks of it. One day your life will flash before your eyes......................................make sure yours is worth watching!
24th Aug 2016 2:31pm |
