![]() | Home > Maintenance & Mods (L322) > Front suspension clunk |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Forgot the Struts are also less then 2k miles old. OEM unbranded Delphi. |
thrillcat Member Since: 04 Jan 2018 Location: Ames, Iowa Posts: 23 ![]() ![]() ![]() |
Sway bar bushes. I just had them done, and it got rid of my low speed clunk. https://www.ebay.com/itm/New-03-12-Land-Ro...2749.l2649 2012 L322 5.0l NA Santorini Black / Sand |
Was this a shot in the dark or could you visualize wear or movement? |
Finally got a mechanic that is on the ball. Range Rover and Jaguar factory trained so he hates working on them but a wealth of knowledge. He feels that there is some play in the swaybar bushings but not much. His online mechanics association that tracks difficult to find/DX problems reported 36 customer complaints of clunk being bushings and 15 from "rag" connector in steering column. I can't find that in the RAVE but I don't feel any steering wheel impulse with the clunk. |
Finally got a mechanic that is on the ball. Range Rover and Jaguar factory trained so he hates working on them but a wealth of knowledge. He feels that there is some play in the swaybar bushings but not much. More of a horizontal play than vertical so I guess I will do that next. His online mechanics association that tracks difficult to find/DX problems reported 36 customer complaints of clunk being bushings and 15 from "rag" connector in steering column. I can't find that in the RAVE but I don't feel any steering wheel impulse with the clunk. |
End link play can be see but IIRC you need to get both front tires off the ground so not to tension the sway bar. Find this first then see what is left. |
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 14 ![]() ![]() ![]() |
Hi all. Hoping this may help someone but unsure where to post it really.
Just an update. Haven't changed the bushings out yet but noticed how higher tire pressure stresses any front end joints. I just picked up the RR after it sat at mechanic for a week. Front tires were low to about 25 psi. In driving the 12 miles back with the low pressure absorbing bump impact I rarely heard the swaybar clunk. After filling to 42psi it brought it out again. It also brought out the very early wear sound in the wheel bearing. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
42 psi??? No suspension left in the sidewalls at this pressure!
Maybe but max tire pressure is 55 psi on the Pirellis. Still has some give. That said this tire is the one with just a bit of feathering. Sounds plausible the extra pressure and extra pavement slap from the feathering causing odd sounds. The next step was to put this tire back on the rear and see it the noise changes. Needs to go in for inspection (MOT) and an alignment check. I'll have it rotated then. I've never run these at stock pressures. Just the leaky low in the 20s which was quiet. Well I would be ecstatic if that is all it is but I will refrain from getting my hopes up. |
I'm curious as to which Pirelli has max pressure of 55 psi. I've seen 44, 50, 65 and 80 but never 55 on any brand. |
I'll check the actually pressures. I know it was 50 something. Just guessing the middle range. |
50 psi. Not 55. Some did have 51 max. These are 235/65 -19. The extra inch or so in diameter put my speedometer dead on with GPS and radar. |
