Home > Off Topic - Other Cars > turbo upgrade not what you think
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I wonder if you could convert the suspension air compressor to this
 L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #399440 6th Aug 2016 9:23pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Simple solutions usually the best. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #399463 7th Aug 2016 6:44am
And we have a bigger tank.... There is nothing that can't be fixed with a hammer😜😜
Post #399472 7th Aug 2016 7:59am
RiccartonRR
Shocked Shocked Is a modern diesel not complex enough?? Big Cry Big Cry Back in a Defender!!
Post #399556 7th Aug 2016 7:12pm
Replaces unreliable Vgt turbo tech with a pretty simple pump and tank, so may make things better👍😄 There is nothing that can't be fixed with a hammer😜😜
Post #399558 7th Aug 2016 7:54pm
fisha
Why not bolt on a belt driven compressor with clutch activation like a AC compressor. Then have it run when the engine goes into overrun or brakes are applied, that way using regenerative energy in the immediate run up to when your going to need the next boost. I.e,when you decelerate its a likely expectation you'll accelerate immediately after. A motor pump bolted on the side of an blue cl would burn out in no time. V8 or else ...
Post #400122 11th Aug 2016 2:19pm
