![]() | Home > My Range Rover > Just joined the club |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Welcome. I've also 40 plus years of motor vehicle ownership of which I have mostly done my own servicing/repairs.
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
Welcome to the Fatty Club! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
Welcome...
Xray charlie Member Since: 22 Jul 2016 Location: Derby Posts: 48 ![]() ![]() ![]() |
Thanks for the welcome, profile updated, yes I have Lynx for diagnostic and thanks Pete I've checked out the thermostat kit although it will wait until I rebuild engine top end ( suspect HGF) |
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 ![]() ![]() ![]() |
welcome hope you enjoy and have cash to spare in the bank |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
Very classy interior! Aspen green leather?
Only take pictures with the iPhone with it in landscape (ie sideways) with the volume keys at the bottom, then they appear OK... this used to happen a few years ago and apple sorted it with a software upgrade, now the upgrade before last messed it all up again... rather annoying... |
Oh, and what makes you think the head gasket has failed..?? Pete
Re possible HGF, here's the full saga.
Hi Dolphinboy, I didn't know what it was called but have always liked this colour combination, it'll look even better waxed & valeted, but mechanicals are calling first;) |
These can be a pain to bleed, a small airlock will over pressure the system, lots of heat cycles and topping up should get there, doesn't sound like a typical HGF to me, I'd explore other options first, swap plug/coil to a different cylinder and see if the fault moves...
Sorry about the delay in replying, I've been away on holiday with no internet! So to cover the earlier issues
Typo in above, that should read TILT motor had lock up issue. |
RuthlessGK Member Since: 28 Oct 2015 Location: Sheffield Posts: 83 ![]() ![]() ![]() |
What exhausts is fitted to yours pal?
