Home > Technical (L322) > Another dead battery question (sorry)
Sandyt
I had a similar thing withy old p38n and it turned out to be corrosion on the inside of the main feed to the starter motor it woulds turn on etc but not crank then two minutes later it would try putting another cable from battery to starter not sure of the circuit on the l322 but just double it up cables from motor factors about a tenner - it may not be the issue but that was the problem I had apparently when the temperature varies the lead can pass less current worth a look
Post #401691 23rd Aug 2016 1:16pm
bazwd
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Another question about another dead battery question
Good morning.
I have decided that one option to take the worry out of whether my car will start is by fitting a Battery Brain. I have seen this mentioned elsewhere on the forum and a friend fitted one to his Jeep recently, with great results.
Can you advise me, please. Does the BB kit work, is there room for it be fitted into the L322 engine bay, and can anyone tell me where I should connect the mysterious 'black wire', please?
Many thanks
Barry
Post #405337 19th Sep 2016 9:00am
n1cktdv8
Barry,
Not sure this helps now but I have had a few battery fails. The Bosch S5 simply wasn't up to the job. I purchased the AGM battery as fitted by JLR now. It's a different world, never failed and so far so good. Is this where I put the car details and a bit about myself ?........
Post #405338 19th Sep 2016 9:02am
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Sorry bazwd I know this don't help, but why do we buy very expensive vehicles that don't work ? Sad
It's as if we take it for granted that we'll have battery problems etc etc
I've been there mate, and I sympathize with you, it's like a battle of wills when you approach your motor thinking will it start today Shocked
Good luck Thumbs Up
Post #405340 19th Sep 2016 9:15am
bazwd
Thank you for your messages of support. This is the third battery l put on this car, bought after much research and good guidance from this forum. The battery works fine but it's the drain when the car's supposed to be silent that creates the problem. I travel abroad a lot with my work so the car is often parked up for days on end at the airport and baggage reclaim is always a fraught time wondering whether the damn thing will start. Yes l guess l could swap it for an Audi or a Dacia or something else but no car will have the same pull for me as FFRR so l have to live with it l guess.
Best regards
Barry
Post #405609 20th Sep 2016 6:24pm
