Home > My Range Rover > My 2003 4.4 Vogue
mattyp
My 2003 4.4 Vogue
got a few plans for it yet, I am after a new set of wheels. Was this car anyone's on here ? Chrome handle covers are off already
Post #398724 1st Aug 2016 7:51pm
Rilla
Isle Of Man 2009 Range Rover Westminster TDV8 Santorini Black
Congrats, looks a lovely example. 2009 Westminster. Mariana black with ivory leather.
Post #398745 1st Aug 2016 9:01pm
mattyp
A little up date, so far I have serviced it,changed the rocker cover gaskets and the pan valley gasket also.
Post #402280 28th Aug 2016 7:02am
mattyp
Handles have been colour coded and so have the mirror covers, I have removed the old window tint as they were faded and starting to peel. Going to get it re tinted this week. Managed to pick up a mint set of supercharged alloys for £100 with out tyres. Also fitted supercharged rear lights.
Post #402282 28th Aug 2016 7:13am
RR2008HSE
Post #402363 28th Aug 2016 8:15pm
mattyp
Had the windows tinted and put the standard grill back on for the min, just sorting out the parts to do a 2007 facelift
Post #405224 18th Sep 2016 10:46am
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Nice looking car, Matty! Like the wheels - good price, too.
Can I ask where you had the re-tinting done, and where, and how much? Thanks!
Post #405238 18th Sep 2016 12:42pm
mattyp
It cost £200 and it was done at my house here is the link off eBay
https://www.ebay.co.uk/itm/322251352407 he done a good job, even look the door cards off
Post #405246 18th Sep 2016 2:09pm
Stuart
Many thanks, Matty. Thumbs Up
Post #405247 18th Sep 2016 2:25pm
Mickx
Post #405322 19th Sep 2016 2:23am
mattyp
It been a expensive month.the front diff started to whine on Saturday. Then in Sunday I stared it up and the engine made a strange tapping noise. When I removed the sump this is what I found
Post #409149 13th Oct 2016 1:29pm
b348xyx
Unless your doing the work yourself, it will be expensive to fix depending on what needs replacing.
2-3k without vanos units.
3-4k with new vanos units and new timing chains. which i did as may a swell do them at same time.
of course the above depends on what you need but if you’re going to fix don’t skip anything to save ££ as you will regret it later on.
Unfortunately with the age of the 4.4 litres these days the timing guides are becoming old and brittle and in my case the timing chain were quite stretched aswell.
I recently had work done to mine lucky my warranty covered a chuck of the cost.
http://www.fullfatrr.com/forum/topic39687.html
Cheers 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #409165 13th Oct 2016 4:17pm
mattyp
I managed to buy the parts cheap and a friend done the the mechanical work for me. Also fitted a new water pump and colder running thermostat. As the front end was off the car I decided to facelift it.
Post #409486 16th Oct 2016 10:50am
Rewmer
Nice Matt, good to see a another Adriatic 03 showing the rest of the Clacton how we ride. Be sure to give me flash and a wave on passing ......
Post up some pics of the facelift. No7 - 2003 V8 Vogue
Post #411445 30th Oct 2016 5:30pm
mattyp
This month I have put new spark plugs,water temp sensor and a crank sensor, oil and filter change and a new android stereo. After all that it still takes a few seconds to start from hot now and then.
Post #413260 12th Nov 2016 7:01pm
