![]() | Home > Technical (L322) > IIDTool live values |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8545 ![]() ![]() ![]() |
Maybe a tad high, last time I checked mine it was around the 100 mark when fully warm which does take a while to get to.... |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Thanks Pete, |
Well after monitoring my gearbox oil temp for the last few days, its operating around the 100'C which had me thinking strongly of removing my radiator and oil cooler and flushing them out etc to see if I could lower the oil temp,,,,
100deg is what the oil should be running at, another reason to change it regularly... it sets off the overheat around the 130deg mark... |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
You have a 105c thermostat. Things are running well if you are around this temperature. It still looks like you have pretty chilly weather in your neck of the woods, when it warms up dont be surprised to see up to 108c-110c coolant temps especially if you are towing. Your oil and ATF should be the same temp as your coolant after a good 20 minute drive I would have thought. |
Don't think I have a 105'C thermostat. I also have been monitoring the coolant temp and the radiator coolant temp.
Interesting, you have a very wide temperature range?
I haven't used the message center so will have a look. Mine is same as yours then, sitting at 91'C +/- 3'. Not sure what you mean when you say about the wide range. Its the Radiator temperature that is varying as I speed up on open road and slow down in traffic but is that not to be expected. Engine temp stays pretty constant which I assume is the job of the thermostat. Declan
Yes, thats why I say there must be 2 temperature probes possibly more.
Yeah, the reason the thermostat is there is to ensure the engine does not run too cold so that even in freezing weather, the engine will go up to 84'C and will be held at that. Declan
There are two temp sensors, one on the outlet from the top of the engine where the temp will be at it's hottest, the other is in the bottom hose where it leaves the radiator, this will be the coolest part of the system...
"If you have a standard stat then it is 105deg and your temp will be above 100deg when up to temp, it sounds to me like either yours is stuck open or it has been replaced with a lower one or had the, cheaper, modified stat... "
That's what I mean, someone has changed it before, seems you already have a lower temp one in there... which is great as it's one of the best things you can do to reduce the under bonnet temps... |
