Home > Maintenance & Mods (L322) > AJV8 Radiator Replacement
Jupiterrover
United States 2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Fisha, thanks that would be great. Do you have a supercharged 4.2 or naturally aspirated 4.4?
Cappo, thanks for the write up. It was very insightful.
I believe the fan nut is 36mm and a right hand thread. Which is opposite of the older BMW engine left hand thread and 32mm.
Post #406893 28th Sep 2016 11:11pm
fisha
4.2 SC I have.
Might be a short while as I may also do the belts when I have the access. V8 or else ...
Post #406943 29th Sep 2016 9:58am
Jupiterrover
any update on the radiator install?
Post #413640 14th Nov 2016 10:17pm
fisha
Hi there,
Yes, Ive just very recently managed to put the new radiator in along with a new engine oil cooler. I did try and video doing parts of it, but the video hasn't turned out all that great. It just doesn't seem to show things all that well.
I'll try and make something out of it - but don't expect much.
Overall the job was OK to do. Tricky points were trying to get the radiator out past the fan cowling, the pipes and things catch on the plastic. On refit, I ended up breaking a bit of the cowling, but its no big deal. Overall, I'd say that the engine doesn't seem to smell as hot as it did before ... I think the new radiator is that much more cleaner and efficient that it cools very effectively. That being said, I still get a slight whiff of coolant after a run, but I just can't trace where its coming from. Coolant loss appears negligible, if any at all from the tank, so I'm not sure if what I've spilled is taking ages to dry off or not.
In terms of sourcing the radiator, I bought it direct from Glasgow Radiators ... it comes out of the box as an *identical* match to the original that was in, including the BEHR branding and part numbers on it.
Cost me £126 in VAT... Shocked Way cheaper than anywhere else - cheaper cause I picked it up from the warehouse depot. Its not the first time I've got stuff there, and I would go back again. V8 or else ...
Post #414199 18th Nov 2016 9:45am
Jupiterrover
Need Help in Middle of Radiator Swap
I am in the middle of the radiator swap and need some help.
2006 Full size supercharged
All went smooth removing slam panel, hoses and shroud bits. Everything is ready but two problems.
1.) it doesn't look like the two pipe fittings on drivers side will clear the edge of the radiator support holder.
2.) I wasn't able to pull the shroud up high enough to remove from the clips.
Any help would be appreciated.
Post #415159 24th Nov 2016 5:05pm
stu1
Did you manage to get this done? I'm at about the same stage and can't shift the radiator up.
Thanks!
Post #529404 28th Sep 2019 3:45pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
you most certainly can get the rad out with out taking the fan off..
as you said it feels like things will break.
the fan is normal thread not L/H (confused the hell out of me) £10 spanner kit of ebay works wonders.
i took my fan off after rad was out.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #529568 30th Sep 2019 12:19pm
stu1
Thanks Matt, are you saying the fan is anti-clockwise (when facing the fan from the front) to remove it?
Post #529615 30th Sep 2019 7:43pm
MattHughes86
do you know whawt that was almost 3 months ago now......
i think i hit it clockwise when facing it..
the good thing with the £10 ebay spanner kit is that it bends if you do it wrong.....
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #529699 1st Oct 2019 1:37pm
