Home > In Car Electronics (L322) > Annoying clock on instrument cluster
D34NO
United Kingdom 2003 Range Rover HSE Td6 Monte Carlo Blue
Hi all had a look around the site and cant find anything to do with this question i have.
my cars clock seems to bong three times at me when it comes to the hour, not usually a drama but it doesn't even do it on the hour, its always at 59 minutes and i know its petty but it really irritates me is there anyway i can change it to bong on the hour exactly or even just shut it up permanently?
Any help would be appreciated.
Thanks
D34NO
Post #398264 29th Jul 2016 2:12pm
Weegie
Wonder does this from RAVE help?
SYSTEM SETTINGS
Altering the system settings
Your vehicle is delivered with a basic setting for
all displays, which depend upon the country for
which the vehicle is intended.
These settings can be altered to suit your
preferences.
Press the MENU button on the control panel to
display the general menu screen.
•Turn the right rotary control until ‘Set’ is
highlighted.
•Press the right rotary control to obtain a list
of possible settings.
You can alter:
•The language of the display texts,
•The units of measurement for distance, fuel
consumption and temperature,
•The time and date
and the way these are expressed.
The following can also be changed by turning the
control further:
1. Memo
Shortly before the hour, three signal tones
will be emitted. If you have switched on this
function, you will see a soundwave symbol
at the bottom edge of the display screen,
after the day.
2. Audio + OBC
means radio and on-board computer
displays appear on the screen at the same
time.
1. On-board computer display
You can choose whether to have the outside
temperature or your estimated time of
arrival displayed.
2. Colour set
means you select a set of colours for the
display screen from the three options
available.
3. Day/night
means you can switch the automatic
day/night changeover function for colour
set on or off.
GPS-navigation John
GAP iiD BT
Post #398277 29th Jul 2016 2:54pm
mjdronfield
That comes from the BMW days. It chimes 3 times at the 59 minute mark in case you want to catch the news on the hour.....
I'm not joking.... My 1988 735i did it if you set it....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #398294 29th Jul 2016 4:18pm
D34NO
thanks for the replies......i was understanding everything right upto "Press the MENU button on the control panel"......i dont see that on mine, i still have that Censored old 80s looking stereo in it cd player at the top and crappy buttons at the bottom.
Post #398377 30th Jul 2016 9:57am
Weegie
In which case try:
"(Vehicles NOT equipped with Satellite
Navigation).
Reminder signal
An hourly reminder signal (MEMO), can be
programmed, to alert you for example of news
broadcasts.
Press the ‘CLOCK’ button (11).
To set the reminder signal, press the function key
(13) below ‘MEMO’ or ‘ON’ (14).
The signal occurs 15 seconds before each hour."
I can't copy the picture with the button function displays from RAVE but if you press the clock button you then press one of the buttons in a line below the display (channel memory buttons?). It looks as if the one you want is the second from right hand one. It is then, as I understand it, a question of toggling the function on or off. Finishing by pressing the clock button again.
Let's know how you get on. John
GAP iiD BT
Post #398391 30th Jul 2016 11:02am
D34NO
you ledge! cheers ill try it tomorrow , gotta say loving the vehicle but this stereo does my tits in!! seen a few alternatives so may look down that alternative! however if this bonging keeps up im in danger of torching the stereo!! lol as long as i can change that bonging then fine!!! little things ay!
Post #398465 30th Jul 2016 8:03pm
