Home > Maintenance & Mods (L322) > Alarm
Page 1 of 3 123>
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Alarm
Guys and Gals.
The Wife just called and said the alarm on the full fat keeps going off when parked on the drive.
I'm currently at work so cant do anything other than do a search and read up.
One think that hasn't been mentioned when reading is pulling the fuse out??? Can i do this?
I cant have the alarm going off all night and its already 5:10pm so no one is going to come and help at this time of day.
thanks in advance Bow down
Post #397590 25th Jul 2016 4:14pm
its normally the bonnet switch which goes faulty....loads on here re that.. ... - .- -.
Post #397595 25th Jul 2016 4:28pm
rangeseb
From what i read i need to spray WD40.
My main concern is if i cant stop it tonight what do i do? should i disconnect the battery, pull fuses, find the alarm and smash it Banging Head
i wont be home until 7 so im just sitting at my desk panicking
Post #397597 25th Jul 2016 4:37pm
mjdronfield
If it's going off for a reason, but you don't know why, can you stop it with the fob and then lock the car using key? Is the car locked then without the alarm on? Could be wrong.
If it's faulty and going off, not sure.... Battery backup and all that.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #397604 25th Jul 2016 5:17pm
rangeseb
From what the Wife said on the phone, she got home locked up as normal then the alarm went off and has done another 4 or 5 times.
She's pressing unlock then lock again and it stops but starts again when it wants.
Trying to get home asap to deal with it myself but traffic is my current battle
Post #397605 25th Jul 2016 5:23pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Key fob battery???
Post #397606 25th Jul 2016 5:30pm
rangeseb
Going to try the 2nd key when I get in.
I just need it to stop asap. Might juat pull the car battery. Kill it completely
Post #397608 25th Jul 2016 5:33pm
Do try the bonnet switch disconnect first when you get home. .
Post #397609 25th Jul 2016 5:35pm
mjdronfield
So it could be working correctly then? Ie something legit is setting it off. You can't do anything till you get home really.
If the fob had a battery issue, it wouldn't unlock would it?
Worst case scenario tonight, as I assume it's drivable is to block it in and leave it unlocked....for a silent night and diagnose in non sleep hours? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #397610 25th Jul 2016 5:36pm
rangeseb
How do I disconnect the switch? I've read people saying it but not seen how?
mjdronfield5
Was planning the block if all else fails.
10 miles from home now
Post #397614 25th Jul 2016 5:46pm
PaulTyrer
It's a Range Rover!!
Ours at the moment is refusing to lock or unlock with either the remote OR the key! New key on its way though.
Since the key fob has been playing up it has had a tendency to sit on the drive and start flashing the hazard lights for no reason whatsoever, and occasionally setting off the car alarm!
Hoping the replacement keys and subsequent recoding will sort it out though.
It did still lock and unlock though even when the key fob battery was failing, then again when a new battery was fitted it kept giving a Key Battery low warning bong!
Still havent found how to disable the BAE (Bank Account Emptying!) chip though......
Post #397618 25th Jul 2016 5:54pm
rangeseb
Rolling Eyes
Been home for roughly half hour and nothing.
The range is currently like a told off child sitting on the driveway doing/saying anything.
I don't want to start touching and unlocking just incase is some how sorted itself but so far so good...... Whistle
Post #397628 25th Jul 2016 6:23pm
Madmax676
England 2003 Range Rover Vogue 4.4 V8 Java Black
Had exactly the same on mine a few weeks ago. When ever I pulled up on the drive when the engine was hot or the sun shone on it, the bonnet would expand a bit and operate the alarm switch.
I disconnected it to prove it then ended up loosening the plastic fire wall it sits on and moving the whole thing forward a few mm within the slack of the bolt holes - fixed.....ideal...!
Always worth double clicking the key fob when locking to deactivate the internal sensor to prove its not something inside setting it off.
Post #397655 25th Jul 2016 8:58pm
rangeseb
Does anyone have a picture of what I should be disconnecting?
So far so good 10:25 in the PM and nothing.
Post #397658 25th Jul 2016 9:25pm
Rosco
Daft question but has it been raining in your neck of the woods? can be an issue otherwise, leave it open until you can sort it, if they are going to nick it they will anyway Thumbs Up
Post #397661 25th Jul 2016 9:30pm
Page 1 of 3 123>
