Home > Duckworth Parts > Wiper arms and seatbelt buckle
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Hi Dan
Could you quote me for the following (all for 2007 FFRR 4.2 S/C) :-
1) Both wiper arms
2) Seatbelt buckle and 3 replacement bolts (see diagram)
Thanks!
Post #397378 24th Jul 2016 6:08am
duckworthparts
Site Sponsor
Afternoon
Pair of wiper arms £91.50inc vat
Seatbelt buckle + bolts £112.00inc vat
Cheers
Dan You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #397567 25th Jul 2016 2:15pm
unsolicited
Payment sent, thanks!
Can I just check that the arms will fit over the existing aluminium ridged flats fitted to the spindles? I had to return a pair that seemed identical apart from a completely different way of securing arm to spindle.
Cheers
David
Post #397630 25th Jul 2016 6:26pm
duckworthparts
Site Sponsor
arms should be fine, only one part number available now across the range... You can paypal direct using - www.paypal.me/duckworthparts
Post #397719 26th Jul 2016 9:55am
unsolicited
Hi Dan
The arms sent are the same as the ones I had before (and thought were wrong). There has obviously been a change in the way they are fixed. Could you tell me how much more I need to buy to sort this?
The old arm looks like this (sorry about my phone camera's bad focus) :-
That fits on a square ish billet pressed onto the spindle, like so :-
The new arm has a totally different design :-
Do I need replacement (different) aluminium billets to go behind the new arms, or has more changed?
Cheers
David
Post #398453 30th Jul 2016 6:45pm
I think you will find that the piece stuck on your original wiper fitting on the FF is already on the new arm, it will be partially stuck on due to the paint, it should come off with some persuasion and then you can change the one on the FF, if you can get it off as they usually corrode on and need a puller, or discard it and bolt the new arm to the old fitting....
Put some grease on it to help it come off again, don't use copperslip as it's alloy.... Thumbs Up Pete
Post #398469 30th Jul 2016 8:15pm
unsolicited
Thanks for that. The new one is definitely a single assembly, but I recon you might be right that the new arm replaces the old two piece fitting method. Hope Dan can confirm - I'll then get a puller to the old billet next weekend.
Post #398571 31st Jul 2016 7:13pm
Oh right, they have changed them then...... good luck getting them off, needed a large puller, tightened it until it was maxed out then had to hit it with a club hammer 1/2 dozen times to get mine off, they really do stick on well.... Thumbs Up Pete
Post #398577 31st Jul 2016 8:08pm
unsolicited
Ahh. Puller & club hammer. Sounds like a great way to spend a Saturday morning. Looking forward to that (not) Rolling Eyes
Post #398578 31st Jul 2016 8:21pm
I suppose seeing as you don't need that bit you could Dremel it off, maybe easier... Thumbs Up Pete
Post #398588 31st Jul 2016 9:20pm
duckworthparts
Site Sponsor
Can confirm what Pete has said, needs pulling off Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #398636 1st Aug 2016 10:47am
unsolicited
Thanks everyone for the suggestions. Will go the puller route on Saturday & see how I get on.
Post #398707 1st Aug 2016 5:05pm
Start spraying it now with some PlusGas... Thumbs Up Pete
Post #398709 1st Aug 2016 5:09pm
unsolicited
Just for reference to those who are replacing their rusty arms. The new ones do fit straight over the spindles with no adapters. A 3 legged puller removed the passenger side aluminium billet with a bang - but no space to fit it driver's side. My 2 legged puller wasn't man enough so will try again with a better one when it arrives.
Job 50% done. Normal for my fettling weekend.
Post #399444 6th Aug 2016 9:41pm
M4TT53
Sorry to hijack. But can the billet pieces be re-positioned?
Reason I ask is I can't seem to align the wipers correctly to sit on the black strip when at rest, so think if I could spin the billet piece a little then I would get the movement I need.
Cheers
Post #421962 9th Jan 2017 7:39pm
