Home > Technical (L322) > Air con fan
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Air con fan
Had the car re gassed because the air con wasn't up to much. After that was done the air con all working fine,The air con man said the fan wasn't working, checked the fuses and they were ok,so is there any thing else to look for before i replace the fan, and is it an easy job to do, any one on here done it. gone fishin'
Post #397041 21st Jul 2016 7:47pm
They fail all the time!!!
Don't use AC until you've replaced it or you risk problems sir Thumbs Up
Post #397054 21st Jul 2016 9:40pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
It will be the motor on the fan that has gone.
A second hand one is the best way to go, new ones are best part of £400. After trying to repair the motor, I gave up.
I managed to get a new old stock off Ebay for £230.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #397190 22nd Jul 2016 9:27pm
andyboy
Thanks for the advice. Is it an easy job to replace? gone fishin'
Post #397201 22nd Jul 2016 9:56pm
Depends on how handy you are with the spanners!
Front grille off
Front bumper off
Then you have access to all the fixings and wiring connectors to remove the fan (simplfied greatly from RAVE!) .
Post #397205 22nd Jul 2016 10:06pm
andyboy
cheers Joe gone fishin'
Post #397207 22nd Jul 2016 10:11pm
