Home > General > Does the Diesel engine require premium diesel ?
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
As the tittle says, does the TDV8 and the new 4.4 require premium diesel or standard ?
Cant seem to see anything on the WWW
Thanks ! 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #39613 26th Nov 2010 10:13pm
I'm guessing just your run of the mill diesel , i have test driven the new 4.4 TDV8 and the salesguy never mentioned anything about the use of premium or any other diesel for that matter ........ Thumbs Up
Post #39615 26th Nov 2010 10:21pm
Just regular diesel Thumbs Up
Post #39627 26th Nov 2010 11:11pm
jez000
Thanks guys Thumbs Up 2021 P400 Silicon Silver AB
Post #39639 27th Nov 2010 12:20am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Anytime Jez! Whistle
Often use that Shell Power Diesel - cannot really comment on if it cleans the inside of the engine components like they say - but it definately gives it a little more ummfff when accelerating Very Happy
Post #39649 27th Nov 2010 6:13am
SteveMFr
Site Sponsor
Is the TDV8 avail in Canada? Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #39733 27th Nov 2010 2:08pm
jez000
Not yet but I'm just in negotiation for a return to the UK and I'd like another RR, most likely a diesel Thumbs Up 2021 P400 Silicon Silver AB
Post #39800 27th Nov 2010 8:59pm
Paul J.
Simple thermodynamics:
The heat released for a fuel is proportional to the amount of oxygen available for combustion (Google 'cone calorimeter' for reference). Hence, for a fixed dispacement (e.g. 4.4 l) the heat released for regular diesel = the heat released for 'super' diesel. Hence, for a normally aspirated engine there is no gain.
However, a turbo allows greater amounts of oxygen per revolution by compressing the air that goes into the cylinders. A 'super' diesel tolerates greater boost pressures vs regular diesel. Therefore, higher boost pressures = more oxygen = more fuel burnt per revolution = more power.
In practice, however, you are unlikely to notice the power increase, and the 'gain' in fuel economy arising from the gain in power will be more than wiped out by the excess cost per litre of the fuel.
Avoid IMHO.
Paul
Post #39815 27th Nov 2010 11:59pm
