Home > Technical (L322) > Holy Moley, a hole in the airspring on a 2012.....
Not really Stan. It was a pin hole, the rubber wasn't perished. The said they couldn't see what made it fail, possibly a stone or something got stuck in it. There is nothing that can't be fixed with a hammer😜😜
Post #396250 15th Jul 2016 5:35pm
I remember craig telling me that mud and crap can solidify in the airbag crease and cause an abrasion...
handy having the LR warranty then Thumbs Up ... - .- -.
Post #396255 15th Jul 2016 6:18pm
Might be worth putting it in high and jet washing the bags. There is nothing that can't be fixed with a hammer😜😜
Post #396260 15th Jul 2016 6:55pm
..or scrape off the dried up crud with a screwdriver..... Wink ... - .- -.
Post #396278 15th Jul 2016 8:06pm
Typical that is.....
Just get one back and now SWMBOs Skoda has a check engine light on Big Cry
Probably one of the 2 o2 sensors either side of the cat, but without a code reader I don't know which one and unlike the FF I can't just crawl under it to have a look and test them.... There is nothing that can't be fixed with a hammer😜😜
Post #396287 15th Jul 2016 8:57pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I had a leaking front airspring a couple of years back and decided to replace it myself. I didn't notice any odd handling or anything. A short while later the other side went, (probably a coincidence). It didn't take long to replace as I knew the procedure the second time.
If you haven't got a guarantee, I would say it is a relatively easy procedure to DIY. The hardest part is loosening a couple of bolts which are very tight. A long extension bar did the job Smile No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #396473 17th Jul 2016 12:03pm
