Home > Wheels & Tyres > Can 19 or 18 inch fit L322 4.2 supercharged ?
RR-EVO
France 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi, i've read many times those don't fit.
I want to install some mud tires in order to go a little further offload.
Those wheel sizes makes a wider offer of tires.
I'm ready to cut the disk protection a little bit to make it fit if really necessary.
Post #394821 6th Jul 2016 8:11pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I believe 19" are the smallest rim size on a 4.2SC Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #394830 6th Jul 2016 8:46pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
apparently the aftermarket compomotives in 18" will clear brembos (4 pots) with spacers ? but 19" minimum on genuine lr wheels as far as i know
But even then, apparently some later 19" wheels won't clear brembos Rolling Eyes
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #394834 6th Jul 2016 9:07pm
rar110
I understood the 4.2SC has similar front brembos to 3.6 tdv8. 18" Compomotives fit the 3.6.
However, you should be able to get a reasonably muddy in 265/50/20. ______________________________
Post #394848 7th Jul 2016 1:59am
The alloys on my Discovery are RR L322 19" from 2010 MY Vogues and they do fit over the 4.2 Brembos. That's what they were on beforehand.
 Discovery 4 HSE
Post #395024 8th Jul 2016 12:10pm
rar110
The off set of those wheels is interesting. They sit out quite a long way. I noticed the Compomotives sit out quite a long way compared to the original 19" RRV wheels.
Evo I would ring Barry at Compomotive. He will be able to give you an answer. ______________________________
Post #395133 8th Jul 2016 9:39pm
fisha
I have the compomotive wheels on mine. The Compomotive PD1881 18" alloys will fit over 4pot brembo calipers. You have to cut off/remove some metal from some weights that are fitted to the calipers. This in no way affects the working of the calipers. You are only changing something which is bolted to the calipers and not the calipers itself.
Whilst I have 20"alloys for the summer I far prefer the 18" wheels V8 or else ...
Post #395268 9th Jul 2016 4:44pm
rar110 wrote:
The off set of those wheels is interesting. They sit out quite a long way. .
but these are on a Discovery not a Range Rover and the car is fitted with Spacers, so its not possible to compare. Discovery 4 HSE
Post #395493 11th Jul 2016 1:37pm
