Home > Maintenance & Mods (L322) > M60 Thermostat Mod |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8323 |
Pretty obvious when you take it apart, remove the internal fixings for the old stat until the new one fits, can't really go wrong.... nothing needs glueing and make sure you remove and leave disconnected the wiring from the old stat....
5th Jul 2016 10:11pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Thanks Pete - the other forum mentioned have to cut a notch for the bleed valve is that not necessary? If it's just the two notches holding the star in I'll dremel it and do it tomorrow lunchtime while the car is off the road awaiting the cluster to be fixed! Cheers |
5th Jul 2016 10:30pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
I assume you're talking of the M62 engine, not M60.
5th Jul 2016 10:39pm |
Think you were unlucky or the engine hasn't had the correct coolant mix and hence corrosion.... mine was no bother at all, not leaking and I left the electrical bit intact apart from cutting off inside what was needed... no leaks as yet...
5th Jul 2016 10:47pm |
Yes, Pete, the price is a bit scarey!
6th Jul 2016 6:53am |
Right guys - just fitted this this lunchtime - i sawed the turrets off then dremeled them smooth. put it all back together and saw it said i needed to use the allen bolt but i didn't i had used all four normal bolts - is this ok? i started up and bled it leaked a tiny bit so i tightened the bolts another half turn. haven't started again since as i don't want to bleed properly until cluster is back... |
6th Jul 2016 12:56pm |
The normal bolts are a bit short aren't they..?? You may strip the threads out of the alloy if they aren't long enough... That's why they give you longer ones in the kit... Pete
6th Jul 2016 5:51pm |
Sorry Pete - terrible description - the 'normal' bolts were the standard long bolts in the kit not the hex head one. Is it normal not to use the hex head one as apparently you're meant to? And how tight should the be paranoid I've rung them - if it leake a drip like it did would you tighten them all 1/4 turn? |
6th Jul 2016 8:51pm |
Don't really understand what you mean, you should use for new longer bolts, the heads are irrelevant but I believe they put a hex head one in for the lower back as it's supposed to be easier to get a hex socket in there... doesn't matter what you have as long as they are new long ones... you should tighten them to 7 Ibf.ft or 10nm if you use the gaskets in the kit then they should be used dry with no sealant on them, had mine on and off several times and never had a problem with leaking, did you use the roll pins to hold the three bit's together...?? Pete
6th Jul 2016 9:53pm |
It was pre sandwiched together - I only used one gasket as the instructions Said I only needed to as the oring did the job the other side... |
7th Jul 2016 5:22am |
Hi Chaps - ok firstly - leak solved was being a bit of a wuss on the bolts
8th Jul 2016 12:22pm |
Mine runs in the low 90's normally, I don't have a viscous fan, I have set the electric ones to come in at 99, much lower than the 125 it used to get to before...
8th Jul 2016 4:51pm |
Elduke Member Since: 21 Apr 2013 Location: Glasgow Posts: 148 |
I've just fitted the thermostat kit this afternoon along with a new water pump, radiator, shroud and belts will report back if there are any issues
8th Jul 2016 5:30pm |
Hi Guys,
11th Jul 2016 10:29am |
