Home > Technical (L322) > Fuel/non starter
Tubby trucker
Scotland 2003 Range Rover Vogue Td6 Zambezi Silver
Fuel/non starter
Hi new to this site hope someone can help
Long story short the fuel is drawing air some place but don't see any fuel leaks
The engine stopped after having a look discovered no fuel at fuel filter the gauge was still showing 1/4 tank so thought it was maybe the " saddle pump" ? In the tank so filled it to over 1/2 tank ( quite a few trips to petrol station with a petrol can ) now I have fuel thru the filter but it is drawing more air than fuel ! I can hear what I assume is the external pump running and if you stick your ear to the filler hole you can hear what sounds like air getting sucked in has the pump inside the tank anything to do with the fuel delivery or is it only to balance the fuel out inside the tank? Could this be causing the air ? If this pump only balances the fuel out in the tank do I need to get more fuel in to get it over to the side where pickup pipe is
It seems to me that this is the cause ( if there was a leak outside tank/fuel lines I would think there would be a visible spill
Any thoughts to help me along for when I get a look at it tonight would be great
Cheers
Alan
Post #394571 5th Jul 2016 11:48am
Steering sensor
United Kingdom 2002 Range Rover Vogue Td6 Java Black
Hi Alan.
I was just wondering if you found out the answer to this as I have the same problem.
Jp
Post #666067 7th Jun 2023 8:32am
mjdronfield
Might not be related, but when I had my TD6 it suddenly wouldn’t start, no warning…. Was the fuel pump near the sill on the passenger side.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #666084 7th Jun 2023 10:19am
Re: Fuel/non starter
Tubby trucker hasn't been on here since 2016 so I doubt you will get a reply from him...
Start your own thread asking, maybe someone has come across it before, after checking out Marks idea.... Thumbs Up Pete
Post #666096 7th Jun 2023 11:10am
Steering sensor
Yeah that's what happened me, will give this a go.
Thanks Jp
Post #666097 7th Jun 2023 11:12am
Steering sensor
Thanks for the reply, will look into this 👍
Post #666098 7th Jun 2023 11:17am
Joahimz9
Netherlands 2003 Range Rover Vogue Td6 Epsom Green
Im have the same issue.
My l322 td6 2003 getting air in the transparent fuel line on the engine side.
CHecked the Passenger side pump and it is ok.
We bypassed the 5way tube and now it runs.
The only question i have is what is de consequence of bypassing the feed on the 5way pipe / valve?
We now have a direct feed.
Anyone an indea why the returns and feeds are crossed in the 5 way pipe?
Post #666117 7th Jun 2023 4:09pm
